TPI setup on a 1982
However on another note i will say ive had dozens of CFI cars and set up correct they run excellent, sound strange when running but work fine
Single TB and endless supplies of aftermarket options
Fairly well known and respected technology that has many guides, books, articles and most importantly techicans that understand it, tune it and support it.
Without a doubt looks impressive although I do like the CFI look as being unique.
Cost - cheaper parts and replacement items for the most part.
Technology - the ECM that supports it is far more advanced and capable of PROM changes. I'll admit you can add an 87 ECM to the 82 as well...I think from a truck with TBs.
that's the quick off the top of my head list.
I've owned four Z28s and Trans Am with TPI and loved every one of them...they were reliable. Not sure about strange sounding engines, I always thought they sounded normal.
and I'm not against CFI, I just wont continue to poor money into it when I can go a step up.
Now, more towards the original post. I have nothing against CFI. It is a very reliable, simple system if Bubba doesn't get into it. My friend has an 82 and an 84 and he is very happy with them. I do think that TPI has more bottom end torque and better visual appeal. I'm very happy with mine.
Another Cross-fire bites the dust!
Since we are throwing opinions around - the CFI is well known for its limitations. However, it was a "one year wonder" for the C3 and C4 models. A piece of history if you will. There had to be a CFI in order to get us to TPI and so one... I'm willing to bet that less than 50% of the 25,407, '82s made are still on the road WITH a CFI set-up. Mine is, drove her to work today! Now back to the post...obviously it's your car, do as you want but IMHO you should do the valve job, keep the CFI intact and look for another car to add the TPI...or jump into the used C5 market...best bang for the buck! Good Luck!
w/2TONE. Port the daylights out of that Crossfire intake, get your heads done, it will run strong. We have a few guys runnning 13's with those CFI in the C4 sec.If you wanna go TPI, get an aftermarket 180CC head (they are cheap), port the base, aftermarket set of runners and a cam in the 210-220 @.050 range, your car will haul the mail on the street. No need for big TB's etc. TPIs dont make great hp#'s or rev high, but they can make a crapload of low end torque (use a 3.08 gear)that will leave people scratching their heads.
