Shifter console panel help
Old Mar 21, 2006 | 11:36 AM
jac1502's Avatar
jac1502
Default Shifter console panel help
The carpeted panel covers for the shifter do not seem to be held in place very well and like to slip down. I have noticed this a lot on other cars as well and I would like to make my interior perfect and that irritates me to death anyone have any tips or tricks for those panels?
Old Mar 21, 2006 | 12:24 PM
BerniesVette's Avatar
BerniesVette
There are three screws in each panel that hold mine in quite well. I would check the brackets where they attach to make sure they are ok.
Bernie
Old Mar 21, 2006 | 12:44 PM
SIXFOOTER's Avatar
SIXFOOTER
you may need to pull the panels out, reglue the edges, especially the top edge. Then put in the 3 screws Bernie mentioned. with abuse/age the panels get messed up on the edges and are hard to tuck into the underside of the console correctly. Be carefull with the glue to keep it off the carpet
Old Mar 21, 2006 | 01:48 PM
Xakk's Avatar
Xakk
My old panels had taken on the consistency of cardboard over the years, so I used them as a template and cut out a new set out of hardboard I got at Lowes. Everything stays perfectly in place now.
Old Mar 21, 2006 | 03:46 PM
cmac72's Avatar
cmac72
Auto Zone sells different sizes of "nuts" (for lack of a better word) that slip onto the mounting brackets for the panel screws to go into. Replaced a couple of my broken ones and they hold just fine.
To Shifter console panel help
