82 Elect fan switch ?
Old Mar 21, 2006 | 12:18 PM
1-MORTOY's Avatar
1-MORTOY
Default 82 Elect fan switch ?
The PO's of my 82 wired the electric fan to a hot feed so it runs all the time. I figured it was because the thermal switch had failed (& because a new one came with all the misc spares).
The new switch is rated at 113 deg C which is close to 234 deg F & the manual comfirms this. Spec is that the switch kicks the fan on at over 230 & shuts off at 200
That is WAY too hot for my comfort. I would like to put in a lower range switch (like I did in my 85), one that turns on at 200 & shuts off at 180. I know I will have to change the thermostat to a 180 instead of 195.
Has anyone done this or see any problems with doing this mod. The engine is a stock Cross-Fire, no mod other than K&N's & it was originally a Florida car.
Where would I get a switch like this ?
Old Mar 21, 2006 | 12:50 PM
SIXFOOTER's Avatar
SIXFOOTER
that is an auxiliary fan intended to help out in slow traffic and turns on when the head gets to 230 or so, that was concidered normal operation.
Old Mar 21, 2006 | 01:11 PM
1-MORTOY's Avatar
1-MORTOY
Oh, ok.........so I should just put the thermoswitch in that I already have & leave well enough alone. THX
To 82 Elect fan switch ?
