Quick Question
Old Mar 22, 2006 | 02:04 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Quick Question
Ok I just installed a accel super coil hei. Now my car will not start it turns over and is getting spark but will not start which leads me to belive that the ignition module is bad. The one that is in there is a autozone cheap. So my question is to i need to upgrade the iginition module since i installed the super coil or will another cheap one work.
Old Mar 22, 2006 | 02:10 PM
Jims79's Avatar
Jims79
had the same thing happen to me. I replaced mine w/an accel module, why put in any cheap parts now. your trying to add hp & performance cheap parts won't help.
Old Mar 22, 2006 | 03:42 PM
Silver00V6Camaro
well just got back from the getting the igintion modual and installed it still nothing it turns but will not fire any ideas. I have an accell cap and rotor with in cap hei supercoil.
Old Mar 22, 2006 | 03:46 PM
jackson's Avatar
jackson
I understand you also have "something" broken at top of dist shaft?
http://forums.corvetteforum.com/show...567&forum_id=3
Old Mar 22, 2006 | 03:49 PM
Silver00V6Camaro
no got a used distributor from the junkyard rebuild with new weights and sprigs everything is allright up top just not getting fire
Old Mar 22, 2006 | 03:54 PM
jackson's Avatar
jackson
If EVERYTHING else is correct ... the pickup is bad ... you have to pull the gear off & shaft out to replace pickup.
-edit-correct pickup is "Standard Ignition" P/N LX-302
Old Mar 22, 2006 | 04:03 PM
Silver00V6Camaro
ok here another dumb question of the day how do you remove the pin at the end of the grear on the dist.
Old Mar 22, 2006 | 04:06 PM
jackson's Avatar
jackson
It's a drive pin ... you drive it out/in with a punch/drift & hammer.-edit- drive pin ... aka drift pin ... aka roll pin
Old Mar 22, 2006 | 05:01 PM
Kalway's Avatar
Kalway
Sort of a duh question, but are you sure you're not too far advanced?
Old Mar 22, 2006 | 06:19 PM
Silver00V6Camaro
ok it seems to be the pickup so how do you remove the picup once the dist is apart
Old Mar 22, 2006 | 07:45 PM
Silver00V6Camaro
Default arrrrrrrrrrrrrrrrr
Ok got eveything back together now i have a new pickup, ignigtion modual, cap and rotor, accel hei supercoil in cap. Still nothing it is just turning over and not getting fire. I dont know what else to do except try the old coil to make sure i did not get a bad supercoil from advance auto parts. Other than that every thing in this dist is new except for the shaft which was cleaned before i reassembled it. all wires are attached except the tack wire because it broke i will fix that in the morning. This is starting to tick me off i was hoping to enjoy driving the vette over spring break this week with a new dist before going back to college.
Old Mar 22, 2006 | 08:04 PM
1BAD80's Avatar
1BAD80
It could be the wrong coil.
Wire colors are different on some make of GM cars and they give you the wrong one.
Old Mar 22, 2006 | 08:08 PM
Silver00V6Camaro
the one they gave me has yellow for tac and red for bat inside the cap. the part number is 140003
Old Mar 22, 2006 | 08:31 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
all wires are attached except the tack wire because it broke i will fix that in the morning. .
Hopefully, you didn't ground the tach wire... you might check to make sure you have hot to the cap just in case..otherwise, maybe this will help in some way...
click on the pics to enlarge, then float your mouse to get another enlargent button..
Old Mar 22, 2006 | 10:00 PM
Silver00V6Camaro
no i did not ground the tac wire the end fell off and there is no wire exposed
Old Mar 22, 2006 | 10:22 PM
SIXFOOTER's Avatar
SIXFOOTER
Are you getting any spark to the plugs?
check my pulling a boot off a plug, stick a screwdriver in the boot and hold it close to a ground while someone turns the motor over, strong blue spark = good, weak yellow spark = bad, go from there
Old Mar 22, 2006 | 10:29 PM
Silver00V6Camaro
i dont think i am getting spark becasue if i was getting spark wouldnt the car start, but i will check it in the morning becuase it is something that could be the problem. the thin is it turns over but wont fire. when i first installed it i was 180 out and it backfired through the carb so i aligned it and got it in order, but nothing happend so i replaced the ingintion modual and still nothing then i was told in an earlier post to check the stator/pickup well found that was rusted bad replaced that cleaned the shaft and the teeth that are on it that come in contact with the pick but still nothing.
To Quick Question
