Bad master cylinder
Old Mar 22, 2006 | 05:20 PM
mikewho's Avatar
mikewho
Navigator
Default Bad master cylinder
Bought new master cylinder. When bench bleeding front part bleeds fine, rear part will only bleed by gravity no fluid will come out when depressing plunger. Is this a bad m/c?
Old Mar 22, 2006 | 05:28 PM
gerry72's Avatar
gerry72
Maybe but even the bad ones will make pressure, they may leak, but they'll make pressure.
You probably have an air lock in the cylinder. It may be a poor feed hole. You can take it apart in about 30 seconds to make sure the pistons were properly assembled and do a quick clean out with some brake cleaner.
Old Mar 22, 2006 | 05:31 PM
Tom454's Avatar
Tom454
Should be taken apart anyways..... I take all of them apart.... most of them are already rusty on the inside from sitting on the shelf too long.
To Bad master cylinder
