Passinger window problems
Old Mar 22, 2006 | 11:14 PM
77 vette's Avatar
77 vette
Default Passinger window problems
Now that my entire drive train is new or rebuilt it's now time to fix all the smaller things that have bugged me the past 2 years. My passinger window would stick going up or down, I would have to help it to move, I figured the motor and reg gear would need to be replaced. I removed the window, reg and tracks plus I removed the motor from the reg, the motor gear is fine but the reg gear is shot, it also has a toothed doubler attached with three bolts, I don't know if that is a repair but that is trashed too. I need to remove the center shaft to replace the toothed gear but it appears to be welded to a spring. How do you get the gear off this assembly? Thanks
Old Mar 22, 2006 | 11:17 PM
SIXFOOTER's Avatar
SIXFOOTER
I replaced both my regulators, was way faster and less trouble, good to go
Old Mar 22, 2006 | 11:38 PM
77 vette's Avatar
77 vette
Was window alignment a pain? I was thinking of puting everything back (rebuilt) as marked to help in alignment. There isn't alot of info on this in my manuals.
Old Mar 23, 2006 | 06:13 AM
Luft 1's Avatar
Luft 1
Cruising
Corvette Fever Magazine a few months ago had an excellent article on windows. Go to their website and serach tech articles should find it ok.
Old Mar 23, 2006 | 03:26 PM
SIXFOOTER's Avatar
SIXFOOTER
It was a bit of a pain, but the shop manual and there is an article in corvettefaq that helps a lot
To Passinger window problems
