MSD Ignition Box failure symptoms
Old Mar 23, 2006 | 09:33 AM
Highhat's Avatar
Highhat
Default MSD Ignition Box failure symptoms
Can anyone describe if there are symptoms (other than complete failure) that indicate a failing ignition box? Thanks.
Old Mar 23, 2006 | 11:26 AM
rihwoods's Avatar
rihwoods
Only my experience....backfiring,stumble,then nothing....later found a wiring issue thru ignition allowing a surge that blew circuit in box...
Go to MSD site..they have a good trouble shooting guide in their instructions....you can follow instructions to check your system...
Are you having issues ?
Old Mar 23, 2006 | 11:33 AM
JoeRags's Avatar
JoeRags
yea, they have a good troubleshooting guide.
http://www.msdignition.com/1troub1.htm
I had problems with my box once, a voltage spike shorted out a diode or two inside. They fixed it for free, no problem.
Joe
Old Mar 23, 2006 | 11:38 AM
VintageMuscle's Avatar
VintageMuscle
I learned not to clean the electrodes inside the distributor cap....
It won't hit a lick.....get a new cap.
Old Mar 23, 2006 | 04:04 PM
Highhat's Avatar
Highhat
I have a new cap and rotor, plugs and wires and readjusted the carb for the colder months.
But now it seems at that there is what I describe as a blip in an otherewise smooth idle, like a miss or intermittent short.
Old Mar 23, 2006 | 04:25 PM
James's Avatar
James
My expierence with them is they either work or they don't.
Old Mar 23, 2006 | 07:46 PM
carl a's Avatar
carl a
my first box a 6 a failed.....lars has it now,i had it rebuilt by msd and went with a 6 al,, the car still ran,,but lousy,,what happened was,,when i bought the car the guy took off the msd box,,he wanted to keep it,, so i already had the blaster coil,,so i bought the msd 6 a box,,,well from driving with the oil filled coil mounted on my intake(at a angle) a air bubble formes in the windings,,the coil burned out and shorted out the ms d box,,, the car limped home,,, when i went to get the 6 al box i told the speed shop i also needed a coil,and that i wanted to keep the coil mounted on the intake,,,the guy told me that i would have to run a dry type coil,,,a dry type can be mounted upside down if you wish,,but a oil filled coil should be mounted plumb,,so a air bubble will not form,,,to answer your question the msd can fail and the car will runat least it did for me,,,but barely ran
Old Mar 23, 2006 | 10:12 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Got a Crane HI-6 under the hood of mine and have no problems... I hear about alot of failed MSD's..
Old Mar 23, 2006 | 10:36 PM
Gordonm's Avatar
Gordonm
My HI6 is mounted behind the map pocket. It has been there for 6 years now with no problems. I changed intakes recently and went with a dry coil. Runs flawless to 7000+ rpm. I fire the box with a set of heavy duty points mounted in the stock Dist.
Old Mar 24, 2006 | 12:21 AM
rihwoods's Avatar
rihwoods
My MSD 6 lasted for seven years until a surge hit it and disabled it...MSD fixed the box at no charge knowing the box did not fail on it's own...
To MSD Ignition Box failure symptoms
