no power on kick down
Old Mar 23, 2006 | 01:44 PM
palazzopl's Avatar
palazzopl
Default no power on kick down
just replaced the fuel pump(stock) its putting out about 4psi and I replaced the carb, a new edelbrock 600..timing set at 10 btdc..the problem is when I step down on it ,it bogs down ,it sound like its starving for fuel..I didn't have this problem with the old carb..any ideas
Old Mar 23, 2006 | 02:33 PM
MsVetteMan's Avatar
MsVetteMan
Man...........I had the same problem. The EB carbs dump quite a bit of gas!! Do you have a pressure regulator? Also, if your motor is not in good shape, and possibly low compression, you will never get this carb to perform properly. Been there.........
Old Mar 23, 2006 | 03:27 PM
marshrat99's Avatar
marshrat99
Do you have mechanical or vacuum secondaries. Sounds like they're opening up way too fast.
Old Mar 23, 2006 | 03:48 PM
bextreme1's Avatar
bextreme1
St. Jude Donor '06
That's the biggest reason I stick with stock parts. They work!! Problems always seem to arise with aftermarket things and although they are fixable problems, it sometimes isn't worth the trouble. If you're not building a race car or street rod, rebuild the old rochester.
Old Mar 25, 2006 | 01:49 PM
palazzopl's Avatar
palazzopl
found fuel pump pressure 8 psi I installed a regulator set at 5.5 and put in a larger fuel filter.. everything is better thanever
To no power on kick down
