Final Eng. Set Up
Thanks again Jackson and Cardo,
Later,
Sly
Yes, use a carb that u know works - have it tried out on a running engine first.
Same thing with dist/ign if possible and don't get fancy here - install the add-ons later. I was lucky enough to have had lars rebuild and test/tune my carb before start-up - but my old batt let me down.
BTW it just my opinion but if the engine brgs, cam and vlv train are all moly-assembly lubed, oil priming not really needed. In fact oil washes off the moly lube - though it takes a while. And removing the dist then stuffing back in ain't fun while also produce timing errors if not careful.
cardo0
Later,
Sly
Later,
Sly
I think I have a good combo for what I want it to do. Any other input???
Rick
Always check piston to valve clearance, but with those lift numbers, I don't believe you will have a problem.
Glen,are you saying that I need a thinner head gasket for a zero decked block,which mine is? I've had a few guys explain what "quench" is,but I just can't seem to get my brain to accept it.
Later,
Sly
By the way,is Moon Twp near North Hills???
Is your block truly zero decked with your new pistons? ... top of piston truly level with top of block? This thing has gone back & forth for some weeks ... for some reason I thought you DID NOT have a zero deck????
If it's truly zero deck then you best not use VR 5746 (0.026") and look to a FP 7733 (0.041") ... even with FP 7733 and zero deck, your flattop & iron 63cc 360" combo would be 10:1-10.5:1 CR. You really need to verify by measurement exactly what the deck is. If you guess wrong you'll be less than pleased w/outcome.
Please let me know if anything i've said makes any sense,and how far off base I am at this point.Thanks,
Later,
Sly
You inform us with only incomplete bits & pieces ... not good. Now you tell us they're silvolite ... those are NOT forged. You had emailed me that your flattop 4vr "forged" pistons have 1.54" CH ... if you have a stock 9.025" uncut deck then those 1.54 are 0.045" down in hole. If this is so you cannot get a decent quench. If it's not too late have your builder install pistons with 1.560"-1.565" CH and a dish with your 63cc heads ... Silvolite & many others make em. If you must run what you got ... then run a felpro 1094 (0.015") gasket.
A SpeedPro P/N H126CP+60 piston (reverse dome/-16cc dish 1.560" CH) and a 1094 gasket will make 9.44:1 CR w/ your 63cc iron heads & uncut block with 0.040" quench ... it'll work good w/ your 1013 cam.
Later,
Sly
If the heads have been milled twice, you need to find out what the present combustion chamber cc is. Once you know that, and have piston cc, deck height, etc. you can plug this into a CR calculator, I use the one on the Keith Black piston site. You can change the compressed thickness on the head gasket to see what you will have, CR wise, all other things being equal.
Quench is the distance from the top of the piston at TDC to the flat part of the head. In otherwords, if you are the stock 0.025 down in the hole at TDC and you use a 0.026 gasket your quench will be 0.051.
Where it becomes tricky is if you use a headgasket to give you proper quench, +/- 0.040, and the heads or block have been milled, and the pistons changed to flat top or dome, you may end up with a too high CR.
I am running a zero deck block with 12cc dish pistons, 64 cc heads, and a 0.039 head gasket on my 383.
This gives me a 0.039 quench and a CR of about 10.3.
Later,
Sly
DON'T simply deck the block!
Don't misunderstand ... I'm all for having a good quench.
But ... In the broadest (in general) sense ... having a good CR is more important than having a good quench. Best to have both good but if you MUST choose between the two, go for a good CR first.
What you have right now w/ VR 5746 gasket should make about 9.9:1 static CR w/ about 0.071" quench.
If you deck the block 0.010" w/ VR 5746 gasket you'll have about 10.1:1 static CR w/ about 0.061" quench.
If you change to thicker FP 7733 gasket you'll have about 9.6:1 static CR w/ about 0.086" quench. If you are limited as to what you can/will do ... I strongly suggest this approach ... it's easiest, cheapest & will yield a better result than what you've suggested or have now. And no point in grabbing your marbles & hauling butt now ... learn from this ... when you're at the table again, know & show all of whatcha got.
BTW ... GM shipped gazillions of small blocks with + 0.080" quench ... no it ain't the best approach ... but it is what it is.
"If you must run what you got ... then run a felpro 1094 (0.015") gasket."
Yes I am confused...What balance should I try to achieve in regards to CR and quench and when is too much CR a bad thing???
Scratch the 1094 ... I suggested that BEFORE I understood what you really have now.
With latest info, do run 7733 ... but you'd probably be much better off if you'd install a set a cheap, slightly taller, dished pistons and a thin gasket. But ... you tell us you will not change pistons ... so, run the thick 7733 gasket.
I'm not trying to bust your chops ... but simple fact that silvolite flattops are also a cheap piston ... there's nothing wrong with them ... wholesale/jobber about $40/set of 8.
with pistons & block height you've described as having:
CR --------- Gasket ---------Quench
9.5:1------7733/1003---------0.086"
9.9:1------5746--------------0.071"
10.2:1-----1094--------------0.060"
cr calculator:
http://www.campbellenterprises.com/R...o%20calculator
You choose.
Later,
Sly
