Fuel Pump Pressure
Old Mar 24, 2006 | 10:10 PM
Ken P's Avatar
Ken P
Cruising
Default Fuel Pump Pressure
I just installed an Edelbrock carburetor that says not to use more than 6 lbs of pressure from the fuel pump. I checked my pressure in the fuel line and came in at 7.5 lbs of pressure. Do I need to get a regulator to drop that pressure down? If so, any suggestions on an easy solution.
Old Mar 24, 2006 | 10:28 PM
Highhat's Avatar
Highhat
I would get a regulator, Otherwise, you risk having the gas fill up the bowls and flow out of various parts of the top of the carb,
