I have a 70 LT-1 thats been rebuilt, the problem is every couple hundred miles it chews up a water pump/alt/crank belt, it had a non-gm water pump on it before i bought it and after the rebuild i saw no reason to replace, it works fine as far as i know, i have all new pulleys on the engine except for the alternator, my father thinks the alt. pulley maybe shot or that the water pump is a pile of crap and poorly built, his solution being replace both and see what happens, i however would like to know what you guys think. any help is much appericiated.
In all my years I've never had a pulley go bad. Are all the pulleys in alignment? You say the wate pump is a non GM. Are you aware that Vettes have their own water pump configuration? Too much tension because of misalignment in any direction will wear a belt down pretty fast. Its also a good way to throw one going down the road. Maybe someone else will chime in with other thoughts.
I just read in car craft magazine bout the same problem. High performance small block Chevy's had a knack for throwing belts. Seem's the GM factory fix was deep V groove pulleys, which are available. There's more info in the magazine under the section "What's your Problem".
Before belts go,are you getting squeal ? Something else to check is the clutch fan...with engine off,check for play by trying to move fan blades fore/aft..if you get movement/wobble,the your clutch fan is toast...
Rich
the pulleys are aligned and the clutch fan spins pretty freely, the belts do squeal unless i tighten them till the belt only gives 1/2in up and down or less.
I have been a tech for a long time and there are diffrent reasons for belts to wear out
1 misaligment of pulleys
2 over tensioning of the belt
3 rusted or pitted pulleys (in the grove)
4 deterition of the belt ( just old and tired) (poor quality)
i read somewhere that the higher revving engines
should have deep groove or serpentine pulleys installed.
it had something to do with the accessory brackets
actually flexing especially the alternator bracket.
If a vbelt rides on the bottom of the pulley it will be eaten quickly. The belt must grip the sides of the pulleys not the bottom. I had a farm tractor with this problem, changed the pulleys and cured it.
I had a pulley problem on a duel pulley set up where the duel pulley on the crank where the same dia., but the water pump dual pulley were different dia. ( which they are not supposed to be ).. Came out of the factory that way. Eat belt's every 200 miles.. Dealer switched water pump dual pulley to new same dia. one and problem was gone..
