Heads and Block - Please Advise
The engine has 67K on it and the compression checked out on all cylinders. I was pulling the heads to consider either a swap but more importantly to evaluate how the cylinders on the passenger side were burning. In my opinion, and it's based solely on my work on motorcycles and what I read here, the head and valves look great. The reddish color is from the recent injector cleaner but overall I have to say everything looks good.
How concerned should I be with the sludge other then attempting to clean up as much as possible? I'm shop vacing out whatever I can to avoid as much as possible the stuff dropping through the oil channels. I believe I can clean it pretty good and change the oil prior to firing the engine and again after it runs for about 20 minutes. Any advice is appreciated. I hate to pull the engine just because of the sludge as I suspect the lower end is in much better shape.
The cylinder walls look pretty good but I noticed some carbon build up on the pistons but that doesn't look too bad either.
I can send ultra high quality photos to anyone that wants to look a little closer. Thanks in advance, always appreciate the input I get here.
Last thought - I received some input that I should consider swapping out my heads because the significantly smaller intake runner sizes. After pulling the heads, it appears the intake has the small ports but the heads are fine, almost 25% larger then on the intake portion of the heads. Would I gain anything by moving to an L98 head (iron) off a later model 350CID? I'm open for suggestions on reasonable ($800ish) heads if there's a decent gain in performance. I cannot afford the aluminum ones right now so that's just out of my ballpark.
On the heads, going to a 58cc chamber will up your compression significantly, which should translate to more power. I believe each cc lower in chamber size equals .1 in compression gain. By going AL you should be ok. Because of budget constraints I have to change my head plans; I am now considering rebuilding some used l98.
I'll put a floor jack under the transmission for support and I’ve ordered a 2 ton engine hoist and a stand.
I would like advice on where to place the bolts for the chains. Most pull the engine with heads and intake but I'm literally down to the block.
I assume the header bolts would be the right choice but before taking that leap please chime in.
Additionally, what should I expect to pay to rebuild the motor assuming new pistons and rings, gaskets, etc. I've had the heads done at Jay's Machine Shop in Temple, Texas. They did a great job so I'm thinking of going back to them for the engine. If anyone in the central Texas area has a personal experience with a shop please let me know.
I guess it's late to ask but should I have pulled the torque converter off first? I could have rotated the engine and removed the three bolts from the bottom? With the right tilt the whole thing came out and while it brushed against the top of the radiator shroud it was pretty easy going and I did it by myself. Just kept an eye on the transmission to ensure I had it supported and all went well.
I have a feeling putting it back will be a bit more of a chore alone. Maybe longer temp bell housing bolts just to get things close?
Engine stand $37.98
Scratched and open box 2 ton engine hoist for 40% off the sale price - $78.80
Pulling your first V8 – Priceless
I kept the angle of the transmission and engine together until the very end and then the engine was titled way up in the front to remove it. The shaft on the transmission looks fine as does the torque converter. My factory service manual is not very helpful in this area.
Later,
Sly
Is the front seal a prevention issue because I have the engine out? If so, I'll get one on order.
