Changing plug wires on 1980
Old Mar 26, 2006 | 08:19 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Default Changing plug wires on 1980
OH MY GOD, what a pain in the butt. My car was running a little rough and since it had the original (25 years) plug wires I decided to change them out. My fingers are so sore that I am having trouble typing this.
With ignition shiedling, and routing under the motor mounts, it took me about seven hours to do. Now I remember why I got out of mechanical work and started making parts instead. The worst part...? It still runs rough. I think it need a new carb or a rebuild but I'll let my hands heal up before I go in again.
Old Mar 26, 2006 | 08:21 PM
LittleJake's Avatar
LittleJake
I feel your pain, thats why I always call over my gear head cousin and start off with a case of beer and in the middle tell him how I cant do this or that to my car and he says "I can" AND proceeds to do the job just to show me he can do it. lol
Im screwed when he finds out my trick.
Old Mar 27, 2006 | 07:55 AM
Eric79-L48's Avatar
Eric79-L48
Ugh...I just did this on my '79. Took me at least 2.5 hours of messing around. The front wires were the worst going through the motor mounts.
Old Mar 27, 2006 | 08:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Been there, done that. A two beer PITA, sippin' slow.
Old Mar 27, 2006 | 11:56 AM
GUSTO14's Avatar
GUSTO14
OH MY GOD, what a pain in the butt. My car was running a little rough and since it had the original (25 years) plug wires I decided to change them out. My fingers are so sore that I am having trouble typing this....
Tom,
I wanted to use later model 8mm HEI wires (like yours') on my stock '73 ignition system, so I bought the universal HEI set from GM to get all the lengths correct. These come with the correct spark plug boot installed, but nothing on the other end. Not only do they feed through all of the nooks & crannies fairly easily, but I can cut them to the perfect length and then install the distributor boots and terminals. I do them one at a time and the hardest part is removing all of the stock shielding to get access, but after that it's not too difficult a job.
While this won't make your fingers feel any better, it might help the next time. Few jobs within these engine compartments are easy, but this is one that sure looks good when it's all done and the shielding is back in place…
GUSTO
To Changing plug wires on 1980
