Automatic to 4 speed conversion
Old Aug 16, 2001 | 08:50 AM
shamby's Avatar
shamby
Default Automatic to 4 speed conversion
I have a turbo 400 trans in my 77 vette, and would like to change it over to a 4 speed. Does anyone know where I can get some info on how to do this?
Old Aug 16, 2001 | 09:44 AM
Alwyn678's Avatar
Alwyn678
Default Re: Automatic to 4 speed conversion (shamby)
Shamby, U live up by Lake Lanier..I can't imagine anyone in atlanta wanting a 4 speed............Too much traffic... :smash: :cry
Old Aug 16, 2001 | 09:58 AM
shamby's Avatar
shamby
Default Re: Automatic to 4 speed conversion (Alwyn678)
I'll agree with you on traffic. My daily drive is an Automatic. This is my weekend toy. It is much funner to drive a stick in the mountains then an auto. And yes i live about 1/2 mile from the lake.
Old Aug 16, 2001 | 10:00 AM
Alwyn678's Avatar
Alwyn678
Gotcha man.....My daily driver is an auto(SAAB TURBO) as is my vette....I have a friend that owns a shop in Atlanta and he has done two auto to 4 speed conversions..I was thinking about it as well...It is a pain in the butt he says.....I can ask him if ya like what it will cost....
Al :cheers:
Old Aug 16, 2001 | 10:03 AM
shamby's Avatar
shamby
that would be great. Right now my 77 is striped down and no front clip. I plan on taking the body of the car within the next couple of month. By doing this, it may make the change over a lot easier.
Old Aug 16, 2001 | 10:08 AM
Alwyn678's Avatar
Alwyn678
U got it I will ask him this afternoon and e-mail ya back.... :chevy
Old Aug 16, 2001 | 10:12 AM
shamby's Avatar
shamby
Old Aug 16, 2001 | 10:48 AM
norvalwilhelm's Avatar
norvalwilhelm
While the swap is not hard it is very labor intensive and on the tension scale it is a ten. The transmission is easy to swap but go with a five speed T5 instead for the overdrive. The transmission will stand up if driven decently. The hard part with the swap is the peddles. The steering column must come out along with the drivers seat. The dash remain intack. The 10 bolts are mostly easy to remove except for a few witch are a pain in the foot. One bolt took me all evening. You can use a complete hydraulic setup from a camaro or even a mid 80's half to one ton chevy truck. The slave cylinder and master cylinder bolt right on.
The crossmember needs a small amount of work in the form of welding but this is minor.
Keep my address handy if you do this swap and e-mail me anytime for advice. I did this swap last year and it came out very well.
Good luck
Norval
Old Aug 16, 2001 | 10:50 AM
norvalwilhelm
I used this post as a practice to post new pictures and I think I overdid it.
Sorry.
Norval
Thought it was a little big George :seeya :seeya
Old Aug 16, 2001 | 10:51 AM
BOBS-2001-CONV's Avatar
BOBS-2001-CONV
If you're going that far.. I would look into a Tremec 5 speed. They have a nice 5th gear overdrive and a lower first gear to get you out of the hole. I converted my 66 Nova and it made a hugh improvement over the Muncie. It was an automatic originally which I changed to a 4 speed then the 5 speed.
Old Aug 16, 2001 | 10:55 AM
shamby's Avatar
shamby
Default Re: Automatic to 4 speed conversion (BOBS-2001-CONV)
The Tremec 5 speed would be nice, but I was hoping to find a used 4 speed some where and try not to spend a small fortune on the conversion
Old Aug 16, 2001 | 02:43 PM
norvalwilhelm
Tremecs are definitly nice transmissions but hard to find used. A T5 has alot to offer and if not beaten will stand up. They are rated up to 330ftlbs which isn't that far behind the tremec at 350 and 405 for the TKO. If you don't power shift the T5 is will last. It has a 3.35 first and a .68 overdrive. It is small compact but the shifter comes out in the middle of the consule rather in off to one side. This can be modified by bending the shifter of using a spacer. In extreme cases a mustang T5 fits with just a 1/2 inch adaptor plate.
Norval
Old Aug 20, 2001 | 11:56 PM
jcanney's Avatar
jcanney
Default Re: Automatic to 4 speed conversion (norvalwilhelm)
I was thinking of converting my TH350 in my 81, to the "stock" super T-10. Does anyone have any documentation on the hydraulic setup mentioned above?
To Automatic to 4 speed conversion
