Help with power window adjustment 1980
Old Mar 27, 2006 | 07:51 AM
joefloyd's Avatar
joefloyd
Default Help with power window adjustment 1980
I hope someone can help me !! I just installed new wearter striping on my 1980 and can not get the windows to work right. They hit the new weather striping and won't go all the way up with the doors closed. The door panels are removed, and I don't have a clue what to try and adjust. Can you help me PLEASE !!!!
Old Mar 27, 2006 | 07:54 AM
jdp6000's Avatar
jdp6000
Loosen off the four bolts that hold the window tracks down and the two that hold the window going up in the track. Close the door...power the window up until it seats. Then tighten those bolts. If all is well with your track and regulator this should work.
Jim
Old Mar 27, 2006 | 10:43 AM
goinbroke's Avatar
goinbroke
Here's some more info that may help.
http://www.71corvette.com/cn-apr/24.jpg
click bottom right of diagram to enlarge.
Old Mar 27, 2006 | 01:22 PM
joefloyd's Avatar
joefloyd
I thank you very much, the photo is better than 1,000 words. I have fiddeled with this for 4 hrs. and I still have the same problem. With the photo, I understand how it works Thank's you made my day.
Old Mar 27, 2006 | 02:32 PM
IrishJoker's Avatar
IrishJoker
Good luck, after replacing weather striping I had the same problem. Followed instructions in shop manual - (see the diagram above) with no luck - the back of the glass kept trying to run inside the weather stripping and the door frame, if I wasn't watching this it could have broken the glass. So after many many hours of frustration - I took it to a Chevy dealership - paid em the $90.00 buck estimate fee to be told that it was the window regulator assymbly. It was bent and would not allow any more outboard adjustment on the window. Guess what the cost of a new regulator from GM is? $345.00! I said thanks, came home and looked em up at the many parts houses and found that they range anywhere from $179.00 to $189.00 - picked up two one left and one right). Figure I might as well replace both and make both windows work right.
Old Jun 20, 2006 | 09:43 PM
Cleatus Van Damme's Avatar
Cleatus Van Damme
BEST POST I HAVE FOUND ON THIS SITE YET!!!!
I have also been fiddling with "bolt 1" and "nut B" and "screw @!$^&@" for hours to no avail.
Again great post!!!
To Help with power window adjustment 1980
