69 offset trailing arms
Old Mar 28, 2006 | 09:24 AM
mike livelsberger's Avatar
mike livelsberger
Cruising
Default 69 offset trailing arms
I was thinking about installing offset trailing arms and was wondering what companies you all recommend and what all mods need to be done?? I was planning on replacing the rear spring with a fiberglass one and I think it will need to be shortened?? What about the dog-bones, must they be shortened?? Anyone know of any articles on this subject??
Old Mar 28, 2006 | 11:24 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
VanSteel... they are a supporting vendor and can probably answer any questions you have on them
http://www.vansteel.com/index.cfm?fu...&SubGroup=1801
Old Mar 28, 2006 | 12:09 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
The only mod you have to do is install the arm. Nothing gets shortened up. Not the 1/2 shafts or the strut rods. I manufacture and build them for most warehouses and others. You don't need a shortened spring but if you do I can help with that as well. Give me a call and we can chat about your different options.
Dan
800-418-5397
To 69 offset trailing arms
