L-88 Fender Flares
#41
#42
I believe all (full size) L-88 flares sold today are a direct copy of the flares GM sold once upon a time at your local Chevy dealer "over the counter",and yes they did have a part number printed under a layer of resin. The ACI flares are identical to the GM ones sold (quite possibly it was ACI who originally built them for GM) and at $600 (from madvette) they are the best deal out there....F. Gregg lists his at $800....I don`t know where the ZL-1 flare came from as it incorporates the 71 style mud flap but the ZL-1 option was available in 69 so go figure. It was probably Ralph Eckler who grafted a flare on to a quarterpanel and started selling them that way for ease in installation.
.....redvetracr
.....redvetracr
There were, indeed, 2 different "sets" of fender flares. The first "set", used for 1969, were as follows:
GM #3958681-----lh, frt
GM #3958682----rh, frt
GM #3958683----lh, rear
GM #3958684----rh, rear
In PRODUCTION, the SET of the above-referenced parts was known as GM #3976521, but the SET was never available in SERVICE. It was supplied loose in the rear compartment of 1969 Corvettes. The "triggering" option for these to be supplied with a car was NOT L-88 or ZL-1. It was J-56 brakes. Of course, for 1969, J-56 brakes were mandatory with and only available with the L-88 or ZL-1. So, either L-88 or ZL-1 got this set of fender flares and no other cars got them. They were available individually in SERVICE, though.
The second set of fender flares came along a bit later, probably 1970 but, perhaps, 1971. I THINK that these may have been destined for use on the still-born 1970 LS-7 and, when that was cancelled for PRODUCTION, the flares were already "in the pipeline" and were made available for SERVICE. As far as I know, these were never supplied in PRODUCTION with any car. However, I'm still researching this one. It's POSSIBLE that 70-72 ZR-1 or 71 ZR-2 MAY have had them. I don't think so, but it's possible. In any event, these flares were available individually in SERVICE as follows:
GM #3965781----lh, frt
GM #3965782----rh, frt
GM #3965777----lh, rear
GM #3965778----rh, rear
I do not know how these differed from the 69 style, but I strongly suspect the difference is as you described. Also, ALL of the above parts are long-since GM -discontinued.
[Modified by Joe Lucia, 4:40 PM 8/30/2001]
#43
I know this is a old thread but
When saying grafted a flare on to a quarterpanel do you mean that the flares was glued on to to the quarterpanel?
Or saying a little different, put the flare on top on the outside of the quarterpanel?
#44
The original GM flares had a tab that let them hang off the body. To install them, hang the flare from the tab, mark around the inside with a marker, remove the flare, cut the factory wheel lip off, them mount the flare and bond it on. That's a short version, but the way GM said to do it.
#46
In many cases you can put 285/40R18's inside the stock C3 rear fenders on 18x9.5" rims w/5-5.5" BS. FWIW, there are even a few who have stuffed 295's into them with a little frame work. With the added width of flares I'd really be thinking about some 315/35R18's out back. Up front, you don't gain as much width with the flares, and how wide you can go depends a lot on how much BS you want to try and run.
#48
I'll go a little further. Direct answer to your question. NO unless you add some thick "adapters". If you are going to fit 18s under L88 flares consider 18x12s with 5" of backspace and the most common size tire is a 335/30-18. Before you install the flares buy the wheel and tire package of your choise and fit the flares to the tire in order to get "the look" that suits your taste. Some people like the tire at the edge of the flare others like the tire a little more tucked in under the flare. Do a search using "flares" and "flairs". There is enough reading to make your head spin.
#50
1 Post
Here's a couple of pictures and a little more info.
http://www.lateral-g.net/members/yoshino/
Is it your car ?
#53
12" wheels and 335's will do the trick. And I'd give serious consideration to less than 5" backspacing on the 12's (4.5-4.75)
#56
Just spent a couple of hours reading about L88 flares and it looks like 355 tires at the rear is a perfect fit
It did not say if was using stock trailing arms
#57
345/30/19's on a 18x12 with 5.0" BS work also but will fit really TIGHT for clearances on all angle. The 345/30/19 tire is 27.2" vs. 25.8" tall and that extra diameter takes up a lot of room.
#58
That is a 12 wheel with what tire size and BS.
#59
I would love to have a C3 with 345/30/17 tires
But i really think that 18(at the most)or for sure 19 is way to big rims for a old car like a C3. Those big wheels looks very much like they do not belong on a C3.
Just my opinion
Just my opinion
#60
Here is a tutorial for the do-it-yourselfer that wants to know what is involved in installing a set. We had to modify these to have "mud flaps" to fit the 81 body. These are ACI brand flares. They are said to be pulled off an actual L88 race car. I tend to believe it because they are not symetrical. These require a considerable amount of hand work to get them to lay in place and look right.
http://mcspeed.homestead.com/Flare_Install.html
You can see my flares at
www.mcspeed.homestead.com
You can see another set we installed and added the "mud flaps" at www.tropiczoneracing.com
