BB Vibration causes (harmonic balancer?)
Old Mar 29, 2006 | 07:58 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default BB Vibration causes (harmonic balancer?)
I used the harmonic balancer that was already on the short block from an automatic car on my built 454 and reinstalled the 4 speed flywheel from the old engine. Would that cause a vibration?
Old Mar 29, 2006 | 08:05 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
I don't think so. I believe 454s are externally balanced, so both your flywheel and balancer need to be for an externally balanced motor. Since the balancer was already there, it's probably correct. What did your flywheel come off of?
Old Mar 29, 2006 | 08:23 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
The flywheel came off of my #'s matching motor for my 73, the shortblock (and balancer) came out of a chevy truck (I think) I was wondering if the flywheel and balancer have to be "matched"?
Old Mar 29, 2006 | 08:39 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
What motor was the flywheel from ?
Basically the whole rotating assembly has to be balanced together, balancer, crank, pistons, rods and flywheel on an externally balanced enginem you can't just swap out balancers and flywheels like you can on internally balanced engines. THere are some ways to get around this, maybe others know
Old Mar 29, 2006 | 09:03 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
The flywheel was the original one from the 454 from my 73 corvette. The balancer was from a automatic truck engine that was built short block.
Old Mar 29, 2006 | 09:12 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
The internally balanced engines use a neutal balance flywheel and balancer. I don't know a lot about externally balanced but the flywheels are weighted on one side with holes drilled in the weight to balance it. I believe the balancer is too. I think they are to be balanced as a unit, short block assembled with the flywheel and balancer. I know you just put this together and in the car. Would really suck to have to yank it out to balance. Someone will chime in that is more knowlegable on this. Good luck and hope you don't have to get the loader tractor back out.
Old Mar 29, 2006 | 09:27 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Thanks for your nice words but I believe as soon as I get done plowing, I'll be hooking on to the 454. Anybody have ideas?
Old Mar 29, 2006 | 09:41 PM
shafrs3's Avatar
shafrs3
454's are usually externally balanced. Reason being is there isn't enough mass on the counter weights to compensate for the rod and piston weight, so additional weight is needed on the harmonic balancer and flywheel/flex plate to balance the assembly. If you've got unusually lightweight internals, you can have an internally balanced big block. Whoever built the motor will be able to tell you how it is intended to be balanced.
Old Mar 29, 2006 | 10:44 PM
evalu8r's Avatar
evalu8r
I believe you are supposed to be externally balanced. 400ci and up typically are. My 383 is and there is an extra weight bolted to the back of the balancer and the flywheel end has an extra plate the goes under the flywheel. Good luck.
Chris
To BB Vibration causes (harmonic balancer?)
