78 Vette
Old Mar 30, 2006 | 12:32 AM
JustinD's Avatar
JustinD
Default 78 Vette
I'm having some problems under heavy acceleration. It seems to "studder". This mostly happens off the line not once your already moving. I think it is in the carb. It is a holly not sure what model. I already replaced the plugs and wires hoping to solve the problem but to no avail. It has the L-48 with an hei distributor and about 35,000 miles on it.
Old Mar 30, 2006 | 12:56 AM
marshrat99's Avatar
marshrat99
Could be lots of things. Here are a few that come to my mind.
1) carb accelerate pump*
2) carb float
3) fuel pump
4) fuel filter*
5) clogged tank sock
6) floating valves
* are the ones that I'd check first
Old Mar 30, 2006 | 01:10 AM
JustinD's Avatar
JustinD
Could you point me in the direction of the carb accelerate pump?
Old Mar 30, 2006 | 01:29 AM
marshrat99's Avatar
marshrat99
The pump is internal to the carb. Here's a link that might help:
http://www.chevyhiperformance.com/howto/45798/
Old Mar 30, 2006 | 03:49 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
just a guess, but looking at your picture, is it possible that your fuel line (it appears to have a bend crimp in it from the reverse angle it is forced to make to bolt up) might be restricting fuel flow?? it might be sufficient under no load situations, but might not deliver enough fuel under load.
i can't tell from your picture, but if the fuel line is resting on the block or intake manifold, or is close to the exhaust in being routed from the pump to the carb, it could be percolating a bit and not delivering pure fuel to the carb (percolation would cause airation of the fuel to a great extent and alter the air/fuel mixture by adding excessive air through the carb delivered by the fuel in addition to the carb suction). this also would be much more evident under load if it wasn't all that severe.
just a couple of other suggestions.
Old Mar 30, 2006 | 04:10 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I agree with the other suggestions. One other thought, for the photo it looks like the choke is closed down too much. You may want to adjust that as well.
As for the accelerator pump, does the studder happen when you jab the throttle? Like it hesitates a little? Or does it happen once you have your foot all the way in it and it's slow to accelerate while it's popping?
Old Mar 30, 2006 | 04:27 PM
73'454folendore's Avatar
73'454folendore
That looks like a pretty bad crimp in the hose. Try fixing that first. Good luck
Old Mar 30, 2006 | 05:12 PM
NC C3's Avatar
NC C3
also check the rest of yor fuel line, especially the short piece of hose that connects the fuel tank to the hard lines running forward....it may be cracked/deteriorated allowing your fuel pump to suck air too. Don't ask me how I know this....I have just gone through a 2 week ordeal with my '78 that was exhibiting the same probs you're having. It drove me nuts You'll have to drop your tank to check this, so while you have it out, it's a perfect opportunity to check and clean the tank inside and that pick-up "sock".
Old Mar 30, 2006 | 05:45 PM
JustinD's Avatar
JustinD
Ya, I just replaced that peice from the hard line to the pump. I think that the bend in the line may have been the problem.
Old Mar 30, 2006 | 05:48 PM
AlCherry's Avatar
AlCherry
Old Apr 1, 2006 | 01:55 PM
JustinD's Avatar
JustinD
It wasn't the bend in the line it was just an illusion in the picture it wasn't kinked much it is just because the line covers are bigger than the fuel line inside. I was thinking that it may need to be tuned were would be a good place to start?
To 78 Vette
