Differential Gear Ratio Question
Question: Is the 68-79 diff carrier essentially a 12-bolt housing that any 12-bolt ratio will work with? If that is the case, then you should have no problem finding a higher ratio (2.73's for example). But, new sets will probably be easier to find. Again, I'd check with a local gear shop as I would imagine they may also have some good, used gear sets.
Best of luck!
NOTE: My 68-69 NCRS guide says:
'68 - 2.72 ratio WAS offered with rear axle code 'AY' and an application of 'HD P THM 427' (Heavy Duty, Positraction, TH400 and 427 cu inch).
'69 - 2.73 ratio WAS offered with rear axle code 'CAY and an application of 'P THM 427' (positration TH400 and 427 cu inch).
But, I don't know if there was a difference in the diff housing offered on these applications vs. yours. Other more knowledgeable folks may be able to advise.
Also, I am sure I have seen 2.78 available in the those years.
Now, even though the richmond is a cheaper box what is it going to cost you on top of the box to build a 2.78 rear end?
I think it may work out cheaper and less work to go with the Tremec.
I'm thinking about changing mine - it seems like a perfect match for a 3.08 rear. I like the 1-2 gear spread better too.
How's it going. You can get a Tom's 273 corvette gear to fit your car. I have used them. The last one was in a 76 w 4 spd in fact. I didn't think they would work good with only a 264 1st gear but the guy loved them. The speedo gear may be a trail and error fit if that's important.
I can get them if you want. How's the box by the way?
Gary
