ZZ4 heads / exhaust header question.
I am going to switch my stock L-48 over to the ZZ4 motor soon.
What type of exhaust ports are on the ZZ4 motor ?
Will I be able to use my stock exhaust?
Will I need "special" headers, or will normal headers for a 1980 Corvette w/ 350 work.
Thanks,
You should be able to use your stock manifolds, but wh would you want to. I would reccomend going the extra yard and step up to a nice set of headders. The ZZ4 will produce much more HP than you stock motor - provided it breathes properly. Using the stock cast Iorn manifolds will greatly reduce the Breathing capability of the ZZ4. If you are going to spend 3k on the motor spend an additional 500-700 on headers and exahust, it will be money well spent.
BTW... the Hooker Headders will fit on the ZZ4 with out modifications. A couple of the plugs are a little hard to reach but they definately work. See sig! :D
[Modified by Mike69, 9:20 PM 8/16/2001]
John
John
Honey ??? where did you hide it this time ??
I will, today, start with my own transplant of my L48 to a ZZ4. I'll be doing this myself, with the help of my friends. It'll a few days after the removing the motor to clean up the engine bay. Then will install the ZZ4, probably next weekend. After reading about the Heddman headers at the pace site, I'll be saving my pennies to buy them... I'll re-install my stock manifolds for now...
BSeery, if you need any support or have any questions, feel free to send them my way. I don't promise to have all the answers, but will give you any moral support you may need. I think you have already decided to go with the ZZ4, in my opinion, its not a bad choice.
I know that I will be doing my swap in about 1 month. I am sure others will be doing a swap shortly or have been thinking about it.
If you could document all the steps that you had to take to change out the motors and the problems and solutions, maybe others would take the plunge and put some more power under their hoods.
If not, send me an e-mail with all of the gotchas and warnings !!
