74 valve tick help
Old Mar 30, 2006 | 07:42 PM
Ricks95's Avatar
Ricks95
Cruising
Default 74 valve tick help
Good evening everyone,
Looking for some assistance on a 74 l48 motor. I just helped a friend out by doing the top end of of the motor. Stock 74 piston, edelbrock 60909 64cc alum heads, edelbrock performer cam, intake, & 600cfm carb, comp cam roller tip rockers 1.5 ratio with edelbrock 7.800 pushrods. There is an audiable valve tick and I am concerned. I followed the lash procedure with the cam with no sucess. I am concened that the push rods are slightly longer than stock and this is the problem. Any sugestions and or assistance is greatly appreciated.
Rick
Old Mar 30, 2006 | 08:12 PM
Cory1970's Avatar
Cory1970
Did you break in the cam correctly?
Did you compare the old push rods to the new ones?
What was the motor temp and air temp when you lashed the valves?
What procedure did you use?
Did you check Rocker Arm to spring clearance at full lift?
*if you did all of this correctly there still might be a slight tick because the comp roller tips will always make a little noise. The noise should be fairly even across all of the valves.
Old Mar 30, 2006 | 08:26 PM
Ricks95's Avatar
Ricks95
Cruising
Cory,
Thanks for the input. As far as the cam goes it has been broken in properly since it has been running in the car for 2 years now. The push rods are .120 longer than stock, I believe, this was going off the recomendation from edelbrock's notes on the head when using roller rockers. As far as the lash goes it was set cold by hitting every closed valve and adjusting till tight then 1/2 turn more. The noise is even across all of the valves. One other note the rockers are not self aligning.
Rick
Old Mar 30, 2006 | 08:40 PM
Cory1970's Avatar
Cory1970
Rick,
That sounds great, but I have a few questions. Are you using roller tip rocker arms or full rollers (comp magnum roller rockers or Pro magnum roller rockers)? How cold was it outside? What procedure did you use to make sure the valves were closed? When you say "tight" are you refering to Zero Lash or did you actualy tighten them down? I am not sure if you have to use self aligning arms on those heads, check the edlebrock site.
Cory
Old Mar 31, 2006 | 05:39 AM
emccomas's Avatar
emccomas
Rick
Had a similar problem on a 73 L48 car many years ago. Finally got a mechanic's stethoscope and determined that the sound was coming from the front of the engine, low on the passenger side.
Bottom line, it turned out to be the fuel pump rod (from the cam to the pump). Replaced this rod and all was fine. Sounded just like a lifter tapping.
Old Mar 31, 2006 | 04:29 PM
73'454folendore's Avatar
73'454folendore
I had the same problem and thought it was the valves. Changed the fuel pump and it took care of the ticks.
Old Mar 31, 2006 | 07:55 PM
SmokinBBC's Avatar
SmokinBBC
Cold adjustment may only get them close. Need to adjust them hot with engine running to get it right.
Old Apr 6, 2006 | 10:03 PM
Ricks95's Avatar
Ricks95
Cruising
Thanks every one for the help. Discovered the problem the push rods were .1" too small
To 74 valve tick help
