Rear brakes dragging
Old Mar 31, 2006 | 07:56 PM
palms's Avatar
palms
1st Gear
Default Rear brakes dragging
Can anyone help, rear brakes are dragging bad. The pucks move free when pushed on. but the pads are not in the center with the rotor. ON both wheels the inside puck is pushing out and the outside is flat against the caliper. looks like rotor is not centered bought new rotors and calipers, lines (steel and rubber) master cylinder booster proportioning valve are all new. Thank you
