Tight when turning engine by hand....
Old Apr 2, 2006 | 09:46 PM
BanGnGearS's Avatar
BanGnGearS
Default Tight when turning engine by hand....
After i installed my engine and connected it to the transmission it seemed to be a little harder to turn.. def over 15 ft lbs, but not extremely tight.. everything is hooked up.. all linkage and 5 out of the 8 plugs are in.. i work nights and i've been workin on the car all day, dont ask.. .... is this normal? or should i be worried?
Old Apr 2, 2006 | 09:50 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
well compression will do that
MsVetteMan's Avatar
MsVetteMan
Very Normal...you got the plugs in? Even harder with them in.
Old Apr 2, 2006 | 10:02 PM
BanGnGearS's Avatar
BanGnGearS
I kno the concept of compression but even the 5 out of 8 will cause this effect.. I built the engine with someone who i thought was a dependable engine builder, an the engine would not turn over.. had to rebuild again.. also has anyone ever torqued their roller rockers while the car was idling with the valve covers off? i hear that this is the most accurate way of doin it.. any comments on that?
Old Apr 2, 2006 | 10:29 PM
wnjlt1's Avatar
wnjlt1
if you are still a little concerned, remove all of the plugs and then recheck to see if it's still tight.
are you running hydraulic, solid or a roller cam? if hydraulic, Lars a write up on this
https://www.corvetteforum.com/techti...=116&TopicID=3
Old Apr 2, 2006 | 10:57 PM
BanGnGearS's Avatar
BanGnGearS
thank you for that link.. it will definitly come into play within the next day or two
To Tight when turning engine by hand....
