The first one I think might be a ground issue. The back courtesy lamp of my 71 doesn't work. I hook my power wand up to the ground of the battery and touch the recepticly and it says there is power there but when I put the light bulb in no light. Where is the ground location for that lamp?
Second is the more difficult one probably a ground issue too but I don't know. The two front left running lights don't work. They blink when I use the turn signals and the one on the side works when I take out the front ones light bulb. I tried to use my wand to check for power on the front one but got nothing. So is it a ground issue, a light bulb issue or a straight power issue?
