Electric Fans
Old Aug 17, 2001 | 02:58 PM
veech's Avatar
veech
Default Electric Fans
Im Gonna Add electric Fans to my Vette So it Runs cool.
How should i set up the Fans, Should they Puch air out of the radiator or Suck air Through it?
Old Aug 17, 2001 | 04:40 PM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: Electric Fans (veech)
Pullers flow more air, according to the manufacturers.
AC
Old Aug 17, 2001 | 05:15 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Electric Fans (A C)
You live in a moderate area so I would recommend the Flex-a-lite 210 dual fans.
Don't buy them from Ecklers, get them from Summit or Jegs for $200.
They fit my radiator core perfectly and work really well.
Old Aug 17, 2001 | 09:48 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You can push or pull. If you want to get rid of the machanical fan, then I would go with the pull type (engine side), if you want to add air flow with the mechanical fan still in place, go with the push in front of the rad. Your radiator is about 18.5 tall x 27.5" wide. I offer the spal 16" hi-flow (2300 cfm) single fan kit for $226. Complete with harness, relay, wiring diagram, fuse link, and temp switch. I stock the pull type but I can get you a push in a couple days. http://www.dewitts.com
Old Aug 19, 2001 | 07:32 PM
74 Vette's Avatar
74 Vette
Default Re: Electric Fans (BSeery)
BSeery,if you wouldn't mind telling did you use yours as a "backup" or did you do away with the mech. fan all together.I have a 74 and I am thinking of dithcing the mech.fan.
Thnks ahead for any opinions.
Old Aug 19, 2001 | 07:47 PM
Brutus's Avatar
Brutus
Default Re: Electric Fans (74 Vette)
I just installed the twin Flex a Lite fans. They work great and look good as well. Really open up the front of the motor.
To Electric Fans
