overfilled the tranny. need advice
Old Apr 4, 2006 | 04:40 PM
73'454folendore's Avatar
73'454folendore
Default overfilled the tranny. need advice
After replacing my Th400, I refilled the fluid. I wished I would have installed a plug in the pan while I had it pulled. Question is if it is overfilled by a quart will it damage the tranny? Other than dropping the pan to drain it any other suggestions as to draining the fluid? I though about removing the Tranmission Modulator might be the easiest route. Any help would be great, Matt
Old Apr 4, 2006 | 04:57 PM
tellcom2001's Avatar
tellcom2001
go to the auto parts stroe and buy a siphon hose kit that fits the tranny fill hose.and pump out the quart
Old Apr 4, 2006 | 05:07 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Default over filled
Unhook the supply line to the radiator cooler, slip a rubber hose over the open line and direct it into a container. start the car and run for a few seconds till you run out enough. You can always add back if too much comes out.
Old Apr 4, 2006 | 05:23 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
yep. Don't know if you'll even need to START it actually, if it cranks over fast enough.
Old Apr 4, 2006 | 05:25 PM
VETTEVIC's Avatar
VETTEVIC
put something under the tranny to catch the fluid and remove the dipstick and tube. you can put a pump for a soap bottle or hand cleaner in the dipstick hole and pump out any extra that didnt come out when you pulled the tube, then reinstall the tube and dipstick. If you dont get the excess out it will cause problems for the trans by foaming and if it sits overfull too long it will start leaking all over the place.
Old Apr 4, 2006 | 05:40 PM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
All good advice so far...any chance you ahve a good/newer torque convertor with a drain plug?
Jim
Old Apr 4, 2006 | 06:10 PM
73'454folendore
Jim
I did just replace the torque convertor and flexplate. The new TC did not come with a drain plug. Removing the tranny fill tub is not an option with the clearance I have. I would have to drop the tranny to do this. I will try the siphon meathod or pulling the Tranny modulator. Thanks for the info. I was more worried about damaging the tranny with the extra fluid in there. It does drive great and shift without any problems but that was just a couple of trips around the neighborhood.
Old Apr 4, 2006 | 06:47 PM
jdmick's Avatar
jdmick
I would use some 1/4" clear fuel hose for small engines. Get about 8' of it. Shove it in the dipstick hole and siphon it up. With the clear hose you shouldn't have to drink any of it.
Old Apr 4, 2006 | 06:58 PM
73'454folendore
Thanks, I think thats probably the meathod I will try first. I'm just going to use the next door cat for the siphon. I heard cats like radiator and tranny fluid. I don't care for the taste myself.
To overfilled the tranny. need advice
