how many teeth on 81 flexplate?
Old Apr 5, 2006 | 10:22 PM
a1sensei's Avatar
a1sensei
Default how many teeth on 81 flexplate?
My headers seem to be frying starters left and right. I am looking at some mini starters that would give more room for heat shields, as well as just being farther from the header. They always say "for 168 (for example) tooth flywheel." Anybody know? Thanks and God bless, Sensei
Old Apr 5, 2006 | 10:40 PM
big_G's Avatar
big_G
Yours should be 153 tooth.
Mini-starters usually have 2 positions for both size flywheels.
Old Apr 5, 2006 | 11:01 PM
a1sensei's Avatar
a1sensei
Thanks Big!
Old Apr 6, 2006 | 10:25 AM
68 NJConv 454's Avatar
68 NJConv 454
You're should be a 153 tooth 10.5 inch setup. Which means your flywheel has a 10.5 inch diameter with 153 teeth. Your clutch and pressure plate must also be the same 10.5 diameter.
Old Apr 7, 2006 | 07:39 AM
UKPaul's Avatar
UKPaul
er...... my '81 has a 168 tooth flexplate AFAIK. I fitted a th200-4r trans & the converter cover hit the flexplate. I was told that this was because the cover was for the smaller 153 tooth plate, whereas the '81 had a 168 tooth one?
I'm confused!
To how many teeth on 81 flexplate?
