Sporadic miss under a load...HELP!
Ok...now that I got that outa my system, here's my problem. Car starts perfect, idles great, revs to 4K+ in park great...out onthe road from low rpm (1000-1500) in any gear if I stab it it will accelerate with sporadic hesitation. If I'm rolling along at say 50mph and 2500 or so rpm and punch it, it kicks down like it should and does pretty well with no hesitation. (stock TH350 with 92K on it)
The motor is a new GMPP 383 with about 1200 miles on it. Here's what I have done to date to try and resolve this:
New plugs (AC Delco)
new wires (2 different sets - Belden and Moroso)
new coil, module, cap, rotor
Timing is all in at 32* by 2800 rpm (32 recommended by GM for Vortec heads-tried 36* as well with no improvement)
Carb is freshly rebuilt Qjet (Lars)
new mech fuel pump
tank was just dropped and cleaned; sock cleaned; fuel lines purged and all flexible fuel hose replaced with new.
WTF am I missing?? Could a failing torque converter of tranny be giving me these symptoms?? I am at my wits end with this damn thing. Any ideas from you "seasoned veterans"??
Then, when you get to higher rpm's it is fine. Likewise, when it is in park, the torque converter does not play a role. Here is the link that sperkins gave me. http://www.tciauto.com/tech_info/tor..._explained.htm
Just a thought.
Also did you convert a points ignitoin to a HEI style? If so points style has a resistor in one of the wires that you have to take out if you go to HEI style or else you wont get proper voltage to the coil..Just a thought.
good luck..
gonzo
Just a thought.
Do you have any black smoke coming from your exhaust when it's giving you trouble?
this isn't a "big cam" stroker, it's a fairly mild roller.
Hmmm. How did the plugs look when you replaced them?
Are the fouled plugs on the pass side or drivers side??
gonzo
gonzo
Yeah....I recently added about a half to 3/4 of a quart....no drips where it is normally parked. Honestly I don't really remember exactly which plugs were fouled.....but seems like they were on the pass. side.
