Trans noise, how bad?
Old Aug 18, 2001 | 06:13 AM
Jim 77's Avatar
Jim 77
Default Trans noise, how bad?
My 77 has started makin a new noise, and I am wondering what I am in for.
If I nail it in first, sometimes second, it makes a grinding noise. Sort of sounds like I am dragging an exhaust pipe across the pavement. I had the fluid changed to synthetic when the car was inspected but it made no difference. Is this a clutch issue or the trans? It is a wide ratio 4 speed.
Jim
Old Aug 18, 2001 | 02:07 PM
nunus79's Avatar
nunus79
Default Re: Trans noise, how bad? (Jim 77)
Could be your motor mount is giving way and what you're hearing is the fan hitting the shroud. Just a guess.
Old Aug 18, 2001 | 11:58 PM
Steve Straus's Avatar
Steve Straus
If the mount broke the yoke could be hitting the floor tunnel. Had that happen on my firebird.
I only use poly mounts now because of that experience.
To Trans noise, how bad?
