Well, same problem as last year, and the year before. I made sure return line is working, it is, built a 5/8 wood carb spacer, carb is cool now, switched from Edelbrock back to QJet, it still does this to me. After a driving to store, friends house, turn car off, come back 15 min, won't start...turning over but no fire. I crank a couple times with pedal down and air cleaner off, wait a few min, and it always eventually starts, never has stranded me. I bought some starter fluid and it did it this morning, shot some starter fluid in there, started right up. If it is flooding, wouldn't the starter fluid not and have have another issue??? or not.
It is not flooding. Probly vapor locking, maybe the fuel pump letting the fuel in the pump to carb line siphon the fuel back out of the carb. I would look into that since you say the carb is cool.
hard to start when hot can be a starter prblem, usually it is because the starter is heat soaked, an electric motor that is excessively hot will be weak. In this case he said the motor was turning over so got to look at fuel delivery.
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
How well does the starter motor turn over? If it has to work hard, put a heat shield or heat blanket on the starter. If it turns over fine, I would say your problem lies with vapor lock.
I have a glass fuel filter that was too just above the head mounted horizontally. I moved the filter away from the head and that fixed my problem.
I would look for a fuel line very close to a hot maniflod or exhaust pipe and is boiling when you stop. The air blowing across it while you are moving keeps it cool enough to not boil. When you stop the engine and exhaust actually get hotter causing anything close to them to heat up as well. When you find where it is getting hot put an insulating wrap on it and I believe your problem will be fixed. Hope this helps.
Bernie
Here's an answer....have a couple more beers at the friends house before leaving so the car cools down and you should be golden (or glowing)
Actually the carb is still getting pretty hot despite the wood space. The factory air cleaner holds a lot of heat underneath. I just got home after driving around and checked under the hood, the fuel line on the frame is hot to the touch, all the way up to the carb,and carb is too hot to touch. Its been sitting for 15 min, went back out to start, fuel in clear filter is gone, and when cranking it is not filling up with gas, aside from the occasional splash. It looks like it is sucking air, not liquid. When the car is cold, the filter fills quickly with gas...sounds like vapor lock to me, but what to do about it?
I bought a q-jet heat shield from a forum member and it has helped with my hot starts dramatically. If you cant find an original, Mr. Gasket makes them too.
if the gas cap is not vented to both let air in and out of the gas tank, the heat from the exhaust will create pressure in the gas tank that could cause the fuel to keep going into the carb as the fuel boils out of it and into the engine after you shut it off hot. we have had to add a vent to the gas caps on several corvettes to solve the problem you describe.
I have the same problem. I have Jazz gas tank with vented line out of the tank. Under carb is wood 1" spacer. Carter hd (eleck) fuel pump. Still problem. Now i bought mr. gasket heat shield. Let's see what happenig...???? Any ideas?
Lars helped me out with this type of a problem with a pickup we have. When we'd go to start wed have to crank for a long time. He said to check the fuel pump as it has check valves to keep the fuel up to the carb. When those go bad the fuel will drain back to the tank. Then it takes a long time cranking to get the fuel back to the carb and fill it. My vote is to check the fuel pump.
The logic is there for this type of problem. But his problem seems to be more of a heat related problem, meaning when cold it's fine, when he drives it and then waits 15min, he has the hard starting problem. If it were the fuel pump, it would happen whether the engine is cold or hot, wouldn't it? It could be both vapor lock and fuel pump. Is there a way to eliminate the fuel pump?
Seriously, now....I'm curious why your perticular vette is running so hot that you'd develop vapor lock....which by the by, is what you're experiencing...is it a rebuild, high performance, crater, or is it run of the mill stock?? What cooling fans are you using, stock, electric??? What temp thermostat is in it?? Is the front air dam still there and working?? Have you installed any new weather stripping around the engine compartment that would hold in the heat?? Are you running extremely large headers, duals or anything that would create massive heat???
Basically, did you modify it in any way that would help this problem to occur??
No mods, this is stock 72 L-48, with the exception of alum intake, and a mild cam upgrade. Car runs 190 all day. I do live in Austin, Texas though, which doesn't help.
