"Dinging" my exhaust...?
Old Apr 8, 2006 | 11:40 PM
TonySinclair's Avatar
TonySinclair
Default "Dinging" my exhaust...?
It appears my installer didn't closely examine his work, and now my pass. side downpipe is touching the idler (pitman?) arm, just slightly. Can I heat the area with a propane torch and give it a whack for clearance? Pipes are S/S if that makes any difference...
Old Apr 9, 2006 | 01:15 AM
JonnHeather's Avatar
JonnHeather
You can always put a dent in exhaust, it is not that strong of material. If the installer screwed up, why not just take it back and have him correct it? No sense in accepting sub standard workmanship...
Old Apr 9, 2006 | 01:30 AM
JoeRags's Avatar
JoeRags
but if that dont work, torch and a hammer will do just the same.
Old Apr 9, 2006 | 11:22 AM
PRNDL's Avatar
PRNDL
I actually moved my idler arm about 1/16" to give me clearance for my headers.
Old Apr 9, 2006 | 11:33 AM
JoeRags's Avatar
JoeRags
now that I think about it, the first pair of headers I got hit the idler arm as well. I think they were Hedman's.... got 'em under the christmas tree when I was like, 16 or 17. Ended up sending them back and getting a pair of HOokers. The hooks fit great.
Old Apr 9, 2006 | 12:23 PM
TonySinclair
Not feasible. It's a big ordeal for me to take the car in. Rather DIY...
Old Apr 9, 2006 | 12:29 PM
gator79's Avatar
gator79
if you can remove the idler arm it will be easier to ding it. did mine when I installed my headers. good luck
Old Apr 9, 2006 | 12:37 PM
JonnHeather
If you do have to "ding it", hold a round pipe or socket against the exhaust tube and hit the pipe or socket. Will leave a nice round smooth "ding". It will look better...
Old Apr 9, 2006 | 06:01 PM
JPhil's Avatar
JPhil
I clearanced ("dinged" sounds so...so...crass, low-brow, bubba, doncha know!) my Hedmanns from the idler arm with a torch and ballpeen. Easy, but they were off to replace the starter anyway. Now I'm gonna wrap them, so I'll need to increase the dimple a bit. As long as you make a smooth, shallow indentation it should make negligable difference in the flow characteristics of the pipe, certainly nothing a street car would notice.
I should add that mine only rubbed on the rubber grease boot lightly.
John
Old Apr 9, 2006 | 07:40 PM
norvalwilhelm's Avatar
norvalwilhelm
This is what I was going to suggest. Ding the header doesn't hurt flow , doesn't look as good but it won't hurt the flow.
A propane torch is not the best for heating the pipe but in a pinch it will do. Just takes too long.
Old Apr 9, 2006 | 09:20 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Is this really that technical. Maybe buy a mapp gas cylinder for your torch. They get alot hotter.
To "Dinging" my exhaust...?
