L48 Build
Old Apr 9, 2006 | 09:57 AM
LAYLOW's Avatar
LAYLOW
Navigator
Default L48 Build
Pulling The Motor On A 1978 L48 Replacing The Heads, Cam, Exhaust And Upgrading The Ignition. Does This Combo Seem Like A Good Idea
Edelbrock Heads-edl60979
Hedman Headers-hed68306
Comp Cams-12-211-2
Msd Ignition-6200 And 8412
Looking For Around 300-350hp, Just A Strong Sunday Driver. Any Other Suggestions From The Vette Gods And Experts Would Be Appreciated. Will The Stock Intake And Quadrajet Be Sufficient.
Thanks In Advance.
Old Apr 9, 2006 | 10:05 AM
BerniesVette's Avatar
BerniesVette
I would include an aluminum intake with the Qjet. Or go with the Edlebrook performer intake and carb combo. Just my opinion for what you want out of your car.
Bernie
Old Apr 9, 2006 | 10:17 AM
LAYLOW's Avatar
LAYLOW
Navigator
Is The Stock Carb Sufficient
Old Apr 9, 2006 | 10:55 AM
Ganey's Avatar
Ganey
The stock carb & ig. are fine. Al. intake rec. Trans. & rear gears are needed for cam.
Old Apr 17, 2006 | 10:11 PM
LAYLOW's Avatar
LAYLOW
Navigator
Bernie
I WAS TOLD THAT C3'S HAVE AN ISSUE WITH HOOD CLEARANCE
Old Apr 18, 2006 | 12:28 AM
lawfun's Avatar
lawfun
8th Gear
I have a 78. I pulled my old engine and put in a GM Crate engine, 290 horse which runs on regular. Edelbrock carb and intake manifold and Dynamaxheaders with real duels. It does the trick.
Comp Cams-12-211-2
Thanks In Advance.
Old Apr 18, 2006 | 12:33 AM
lawfun's Avatar
lawfun
8th Gear
Default lawfun
I am trying to replace my seatbelts on my 78 corvette. I can't get the bolts to budge. I used WD40 and have bent more sockets than I care to count. I know about heat but the fuel lines run right by the bolts. Any suggestions.
Old Apr 18, 2006 | 02:54 AM
jackson's Avatar
jackson
Comp Cams-12-211-2
Thanks In Advance.
Stock intake will NOT fit that head ... eb 60979 is an E-tec head & has a VORTEC-style intake flange.
Suggest eb 60899 heads (64cc straight plug rpm), eb 2101 (performer intake), YOUR freshened qjet carb, the CC magnum 270H (12-211-2) is oK. Forget the MSD stuff ... you don't need it ... simply freshen YOUR existing HEI dist ... DO read & heed LARS ignition papers on correct springs & vac can.
Old Apr 18, 2006 | 06:53 AM
Fevre's Avatar
Fevre
For 300-350 on the cheap go with used alum vette heads, summit 214/224 cam, alum intake and your old carb and ign. Use the $ saved to get dynomax coated headers
Old Apr 18, 2006 | 04:37 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
For 300-350hp I'd also be looking at a good set of 1.94 or 2.02 camel humps
Old Apr 18, 2006 | 04:42 PM
GDaina's Avatar
GDaina
This thread is about motors. not seatbelts. If you have a Q regarding seatbelt removal, please start a seperate thread.
Old Apr 18, 2006 | 05:09 PM
frostbitten09's Avatar
frostbitten09
Im on the same with you , I have a 78 with a l48
this is my idea to get around 300-350 hp
Heads, headers, intake, carb, cam.
Sportsman 2 heads. Or the alum. Trick flow 23 degrees ones with 64 cc
Lunati Vodoo cam 221/229 468"/489"
Super comp plus headers/sidepipes
Performer rpm/ or a airgap
Orig qjet or a edlebrock avs.
Later on when i have extra money the wieland 142 blower.
Then a 3.90 rear end of corse , and a b n m shift kit.
To L48 Build
