Offset trailling arm modifications
Old Apr 9, 2006 | 12:34 PM
7of69's Avatar
7of69
Default Offset trailling arm modifications
What type of modifications are needed with this installation (half shafts - length and dia., brake lines & sway bar), also what upgrades are needed that will alow the rear end to support 500+ rwhp -It's a 69 vert, M21, 3.36/1 ratio
Old Apr 9, 2006 | 04:30 PM
norvalwilhelm's Avatar
norvalwilhelm
Offset trailing arms are a direct bolt in. Stock everything works. You are actually just getting extra clearance at the front of the tire. Everything else remains as before.
Old Apr 10, 2006 | 08:49 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Will you be putting slicks on the car?
Old Apr 10, 2006 | 09:12 AM
68 NJConv 454's Avatar
68 NJConv 454
If you want offset TA's go with the double offset TA's from VanSteel. They're the same as the regular offset but the rear leafspring mount is an inch towards the diff. on each side, this allows you to run a shorter spring which gives you more clearance b/w the spring and your rim/tire. (the wider the tire the more this should concern you) Do a search and you'll hear about members having their leaf spring hit their tire resulting in blown tires and suspension damage. You will have to have your leaf spring holes modified but IMO its well worth it. Check it out.
Old Apr 10, 2006 | 02:48 PM
redc3's Avatar
redc3
how and where do you modify the spring?
Old Apr 10, 2006 | 03:39 PM
jimmygmartin's Avatar
jimmygmartin
If you use the extra space you gain from the offset, you will not be able to use a sway bar in the stock location/mounting.
Old Apr 10, 2006 | 07:27 PM
Van Steel's Avatar
Van Steel
You can cut steel springs or you can order shortened fiberglass springs from us. No price increase for that either.
Old Apr 11, 2006 | 09:14 AM
shafrs3's Avatar
shafrs3
What's your view on running shorter springs and not relocating the spring bolt holes on the trailing arm inboard?
Old Apr 11, 2006 | 11:19 AM
redc3's Avatar
redc3
whats the ballpark, if i wanted the modified spring and the offsets with bearings installed?
Old Apr 11, 2006 | 01:19 PM
norvalwilhelm
I shortened a steel spring by cutting on end of right next to the existing hole and then redrilling a new hole. I then measure the distance between the holes and added a new 3/8th center hole. This shortened the spring by about 2 inches. I then used the stock mounting bolts and stock swingarm location.
When you first install the spring with the wheels hanging down it looks weird, the bolts really tip in but once the weight in on the car and the spring flatens out is very hardly noticable. The new shorter spring is 1 inch shorter per side so this leaves a slight twist in the mounting bolts.
The next time the trailing arms were out I offset the mount to comprensate for this but I did run the crooked mounting bolts for years.
Old Apr 11, 2006 | 02:22 PM
Van Steel's Avatar
Van Steel
I think if you cut a 1/2" or 3/4" off each end your fine with standard arms or standard offsets. If you go 1" or more, we recommend double offsets. Some have gone 1" shorter on the spring an have had no problems. I would run doubles in this case just for piece of mind.
Old Apr 11, 2006 | 02:23 PM
Van Steel's Avatar
Van Steel
Rebuilding your bearing assemblies and installing them on offset plus a shortened fiberglass spring will run you about $1245. plus freight. Thats witht the forum 10% discount taken out.
Old Apr 14, 2006 | 11:38 AM
7of69's Avatar
7of69
I plan to add ZL1 flares with a min. tire width of 335 in the rear. The car has a street and saloum suspension package from Vette Brakes that I installed 12 years ago. The fiberglass spring has ruined two tires (255/60/15), will this still be a problem with an 18X10 rim? I want to build this vette from one that I have seen on this forum called Killer or Killer Vette, I think the owners name is Chris McDonald.
Old Apr 14, 2006 | 04:42 PM
Van Steel's Avatar
Van Steel
With 18's your spring will not hit. If anything the spring will sit just inside the rim. With flares you can go lager than 18x10.
Old Apr 14, 2006 | 05:44 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
This is what happens when you have to wide of tires lol. I fixed it though when some mods. My car came with your offset trailing arms already.
Old Apr 14, 2006 | 07:38 PM
norvalwilhelm
How do you cut 1/2 or 3/4 inch off the spring at each end? YOu run into the existing hole? If you cut just past the one hole and then redrill that is about the longest you can leave the spring and yet remove the hole.
Drilling a leaf spring is not that hard, lots of oil, slow speed and a sharp drill bit.
Old Apr 14, 2006 | 07:42 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
The spring rate goes up as you move the hole though.
Old Apr 15, 2006 | 02:37 PM
Van Steel's Avatar
Van Steel
Sorry I meant, getting a fiberlass spring cut shorter.
To Offset trailling arm modifications
