Carb Tuning
Old Apr 9, 2006 | 03:30 PM
VETTE077's Avatar
VETTE077
Default Carb Tuning
Lars? I posted a question a while back about afterburn in the exhaust when letting off the throttle.Your answer was to increase the jets by 2 sizes.I am running a mild cam,headers and dual exhaust with glasspacks. My dilema is that I am using an Edelbrock 600cfm carb. that works well except a liitle slow from a stop.Do I change just the main jets or jets and rods according to Edelbrock chart to richen up the carb 2 stages.
Old Apr 9, 2006 | 07:23 PM
olescarb's Avatar
olescarb
if your problem is a hesitation on acceleration the accelerator pump in the edelbrock performer and thunder carbs has a weak duration spring. we have a custom pump with a stronger spring or you can use a pump from a 800cfm edelbrock thunder or performer (it has a duration spring that is VERY strong and almost overkill) e-mail me if you are interested in our pump is sells for $20.00.be sure your timing cures are correct with at least 12 deg initial and a total of 36 degrees mechanical. our e-mail is olescarb@sanbrunocable.com
Old Apr 10, 2006 | 12:45 PM
VETTE077's Avatar
VETTE077
I am concerned about the afterburn and what Lars said about going 2 sizes bigger on the main jets.I know he usually does Q-JETS and I have a Edelbrock.Timing is ok 36 deg total 12 deg initial.
To Carb Tuning
