SB Power Steering pulley
Old Apr 9, 2006 | 07:25 PM
Xakk's Avatar
Xakk
Default SB Power Steering pulley
What size pulley should go on a SB power steering pump? Mine appears to have a 5 3/4 inch pulley, and if that's what's supposed to be on there, then how the hell do they fit those under drive pulley's on there? They're supposed to be like 25% larger, but with the pulley I've got, the belt is so close to the crossmember that it's actually rubbed the corner off. And that's with the shortest belt I could fit on there. Anything longer and the belt actually binds up.
Is there a smaller pulley, or is it really just supposed to be that tight?
Old Apr 9, 2006 | 07:37 PM
icanfixitforyou's Avatar
icanfixitforyou
I have a 79 with a SB and it is the same way, super close to the frame and even shows signs of rubbing the frame. I do not know about the underdrive pulley for the PS pump.
Old Apr 9, 2006 | 09:45 PM
onaqwst's Avatar
onaqwst
same on my 77...... i want to order pulleys but afraid too....
b
To SB Power Steering pulley
