re-installing rear window on 76
Old Apr 11, 2006 | 06:23 PM
vette4820's Avatar
vette4820
Default re-installing rear window on 76
One morning after removing my interior pieces I noticed my rear window was missing. Much to my surprise it was hanging inside the car by the wires for the defroster. I'm in the process of removing the old adhesive. What type of adhesive/sealer do I need to use to re-install the rear window and what is the process for correctly re-installing it? Thanks
Old Apr 11, 2006 | 07:09 PM
VETTEVIC's Avatar
VETTEVIC
You can use the ribbon (stock type) from any of the vendors or you can use a tube of Urethane window install adhesive available from any glass company or some vette vendors. You will need the primer and need to clean the glass and window frame real good first. If you use the ribnbon like the factory did, you will need to keep the rear window trim in place or it will fall out again as the ribbon is a seal not an adhesive, the urethane is an adhesive. Put the window in DRY first and center it in the frame and see what clearances you need on the edges and use a piece of rubber or wood sliver to keep that space when you put the glass in with the seal or adhesive.
Old Apr 11, 2006 | 08:04 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Or you can take the opportunity to switch to a 68-72 style pop-out window.
Old Apr 11, 2006 | 08:12 PM
vette4820's Avatar
vette4820
Default thanks
would definitely like to do the pop out window one day, just have too many projects going on right now.
Old Apr 11, 2006 | 09:54 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You've already taken a big step if the window is out.
Old Apr 12, 2006 | 05:37 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
when you put it back in, make sure you put the surround back on.. if not, you will be doing it again... dont ask me how i know...
Old Apr 12, 2006 | 12:25 PM
vette4820's Avatar
vette4820
I definitely like the idea of the pop out window...don't really have the time to gather the parts and get it all together right now. I'll take your advice Aflac, I don't want to find out personally how you found out. Thanks
Old Apr 12, 2006 | 01:07 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
experience is the best teacher!
To re-installing rear window on 76
