Max time between engine build & install
Old Apr 13, 2006 | 11:07 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Default Max time between engine build & install
All,
Everything is still up in the air about my rebuild & I'm still vasilating between a full build, a short block build, or a crate engine. If I build it myself, using the premo build lubes, then how much time can I take for the build? This would be a winter build in south Texas so heat wouldn't be a problem. If I build it myself, then I'll build an engine stand for break-in. I can usually ony squeeze a few hours in on Sat & Sun. for any car work.
Old Apr 13, 2006 | 11:15 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I doubt you'd have all the machining equipment to build everything. Can you get a competent engine shop in your area, to build you a shortblock to your specs? And heads? Or, you can purchase some new hi-perf heads that are ready to go out of the box.
Or, have and engine delivered to your door,..plenty of options.
Fellow Texan,
Wes
Old Apr 13, 2006 | 11:21 AM
gavanm01's Avatar
gavanm01
Just finishing mine from bare block up starting in January. Having a mechanic do the work on the engine. Here is the formula I used:
BT= $+AO+CO+BO+BD
HDP
translation:
Build time = dollars+change orders+back orders+budget deficit
divided by honey-do projects
Old Apr 13, 2006 | 11:40 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
BT= $+AO+CO+BO+BD
HDP
translation:
That's about right. It took me 2.5 years to rebuild my 454. Another month to complete the installation working some weekends.
To Max time between engine build & install
