Stock torque converter
Old Aug 19, 2001 | 08:04 PM
Wrecked82's Avatar
Wrecked82
Default Stock torque converter
What is the stall speed of the stock 700R4 for an 82?
Old Aug 19, 2001 | 10:33 PM
Nomad78SA's Avatar
Nomad78SA
Default Re: Stock torque converter (Larry82)
Larry,
I wonder what the stock stall speed is on any of the transmissions 350/400/700R4. I put a 1800 stall in my 78 with a 700R4 overdrive in it with a 388cu motor. I figure my cruise speed would be 2200-2400 rpm and wanted to be under that. Perhaps someone can answer this question.
Neil in Tenn
Old Aug 19, 2001 | 11:32 PM
SuperFast80's Avatar
SuperFast80
Its not a 700R4 but my assemble manual says that my 1980 TH350 is 2100 in stock trim. Hope this helps.
Old Aug 20, 2001 | 10:58 AM
Ganey's Avatar
Ganey
Default Re: Stock torque converter (SuperFast80)
Stall speed depends on torque. When you increase TQ, you can increase stall. Hold brake & mash on gas, check tach.
:cheers:
To Stock torque converter
