How to drop '72 Steering column??
I'm trying to remove my dash panel to get at the speedo/tach...
Everybody says it's easier if you drop the steering column (many threads) but I can't figure out how to do it? I do NOT have tilt/cruise.... is this an easy few step process. I downloaded some of the stuff I found but it doesn't look like mine.
Besides the flexible coupler and the bolts under the dash holding it up, are there other things in my way. Not trying to remove it, just trying to get enough room to get the speedo and tach out. Appreciate any help !!!
but, sadly i'm not a mechanic and some of what he says makes no sense to me. He references a "back drive lever" and unhooking the clutch spring...etc. Maybe all that is necessary for removal, but i just wanna drop this sucker a few inches? And while he references and makes a big deal of the back drive lever, he doesn't show it or say what it is/does...? and he talks about a cable that is used for reverse, (on a manual transmission) and that confused me too...
so i don't know if all of his steps are needed if you are not removing the column?
If all you do is remove the two vertical screws, the steering column is just "hanging" under the instrument cluster by the floor mount and the flex coupling. This puts a very high load on the steering column lower bearing out under the hood and can ruin it.
That is why the best approach is to loosen or remove the two nuts that hold the lower plate to the dash before removing the two vertical screws.
You can probably get away with allowing the column to drop a couple inches down from the dash. However, I would make sure that it is resting on something (or have someone hold it) so that is isn't just hanging there.
Jim
