BBC valve noise?
Old Apr 15, 2006 | 10:26 PM
TonySinclair's Avatar
TonySinclair
Default BBC valve noise?
This is sorta OT, but still related as we're dealing with a 454...
My boat has a 454 with a mild cam and hydraulic lifters. When cold, I have what sounds like a valve making a distinct metallic hammering sound. As the motor warms up, the sound quiets down some, but is still present. Motor runs fine and I regularly run it at 5500 rpm...has not self-destructed yet.
So...is this noise caused by a lifter, valve or bad valve spring? In what order would I start checking/replacing stuff? I want to avoid removing the heads if at all possible due to the cramped working conditions and the fact that the manifolds weigh 100lbs...
Old Apr 15, 2006 | 11:31 PM
SIXFOOTER's Avatar
SIXFOOTER
sounds like a lifter just not quite adjusted in the happy range. They adjust same as on anything else. Pull the covers and adjust for zero lash up and down methode, not turning the pushrod, give it a half turn and fire it up. If it still clatters, see if you can idintify which ones are clattering and give a lil more turn, not more than 1/4. If you have to go more than 3/4 to a full turn that lifter may be bad. While you have the covers off be sure and inspect the keepers and rocker contact points.
Old Apr 16, 2006 | 12:44 AM
TonySinclair
Thanks. I'll give that a try.
Any ideas on how to adjust & test-run without re-installing the valve covers? In order to remove the valve covers, I must remove the exhaust manifolds. In order to run the motor, I must install the exhaust manifolds...
Old Apr 16, 2006 | 01:02 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Do you know what cam is in the engine? Some cams can be noisy, such as Comp's XE line. The steep ramps cause the valves to 'slap' shut and that could be what you're hearing.
Old Apr 16, 2006 | 01:34 AM
TonySinclair
I have the spec sheet somewhere. Can't dig it out tonight.
However, this noise is coming from one particular spot. I can almost put my finger on it. Sounds like someone is inside the valve cover hammering away (with a very small hammer). Tink, tink, tink, tink....
Old Apr 16, 2006 | 08:31 AM
my72vette454's Avatar
my72vette454
Get a big shop towel and lay over the head and that will keep oil from splashing all over your motor.
Old Apr 16, 2006 | 09:48 AM
TonySinclair
I was thinking about getting an old set of steel valve covers and cutting out the tops. Then I'll only have to R/R the manifolds twice...
To BBC valve noise?
