Rebuilt Alt. = Almost fried starter! Why?????
Old Apr 16, 2006 | 10:43 AM
Q's 68's Avatar
Q's 68
Default Rebuilt Alt. = Almost fried starter! Why?????
So I rebuilt the original starter for my 68 vert 327/350. PITA! I then installed the alternator and crossed my fingers...
When I reconneted the battery cutoff, I first noticed that the clock had stopped working and I seemed to have no power to anything
About a split second later, I heard a sizzle and a pop followed by a puff of smoke from the starter I immediately disconnected the battery and checked out the starter. The black wire was smoking hot and I had burnt off the insulation (bubba had just put electrical tape around a spliced starter wire.
I replaced my (obviously) badly rebuilt alternator with a replacement and the car fired right up with no noticeable problems. The question - what did I do to the rebuilt alternator that caused the starter to almost burn up??? Secondly, are there any potential lingering problems I caused by trying to play mechanic again
Old Apr 16, 2006 | 12:23 PM
StickShiftCorvette's Avatar
StickShiftCorvette
The hot wire from the starter to the alternator frying indicates that you had a short in your alternator. I would guess that when rebuilding your alternator you misoriented some of the leads from the windings or regulator to the diodes and caused a dead short. I don't know if a '68 has an internal regulator so the regulator wiring may not apply.
You should be able to check this by taking the checking the resistance from each of the alternator connections to ground BEFORE connecting any of the car wiring.
You may also want to check the condition of the wires that go through the amp gage as that short probably overloaded and roasted that paralell circuit between the starter and alternator.
Old Apr 16, 2006 | 12:55 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
A lot of the auto part stores have a belt driven alternator tester and starter tester you can use for free. Take it in and test it before installing. I bought a 1961 lighter for my 63. Plugged it in the hole without pushing it in while working on the car. 15 seconds later smoke started rolling out from the dash and underhood. I was working under the hood so I disconnected the battery terminal. The lighter on a 63 is unfused. The 63 stock lighter is about 3/16 shorter than the stock lighter on a 61 with the same ****. I didn't know?? The outer case of the element was enough longer to contact the hot in the socket. Dead short! Smoked the underdash and underhood wiring and could have burned the car up. New wiring $800. My labor to install, 2 days. Your lucky this wasn't you as it could have gone the same way.
To Rebuilt Alt. = Almost fried starter! Why?????
