74 Headlight Switch hissssss!
Old Aug 20, 2001 | 12:09 AM
Hava89's Avatar
Hava89
Default 74 Headlight Switch hissssss!
My son's 74 Coupe has developed a hissing sound at the headlight switch on the dash. Typically, what's involved here? Does the switch need to be replaced or could there be vacumm hoses loose? Do you have to take the dash apart to to work on it?
Any assistance is appreciated.
Mike
Old Aug 20, 2001 | 12:55 AM
jdunne's Avatar
jdunne
Default Re: 74 Headlight Switch hissssss! (Hava89)
The ends of the vacuum hoses sometimes split/perish and can be tricky to locate....also check the vacuum hoses on the override switch,same thing happens there.......john :chevy
Old Aug 20, 2001 | 08:39 AM
Ken74Conv's Avatar
Ken74Conv
I had the same hissing sound on mine and the headlight doors did not work. Turned out to be the headlight switch which was new. Replaced the switch and solved the problem. You should be able to change the switch by removing the upper dash pad. :chevy
Old Aug 22, 2001 | 12:02 AM
Hava89's Avatar
Hava89
Default Re: 74 Headlight Switch hissssss! (Ken74Conv)
jdunne & Ken74Conv ~
Thanks for the info! Looks like I'll start digging into dash. Hope that's all that's required Ken to get to the switch. We'll see how it turns out.
Mike :seeya
Old Aug 22, 2001 | 04:08 AM
jdunne's Avatar
jdunne
If you are replacing the switch,spend the extra and replace the dip switch at the same time....it isn't very expensive.......the main switch is lots of fun changing......expect it to take a while........john :chevy
Old Aug 22, 2001 | 10:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The hiss is a sure sign of a vacuum leak at the switch. Could be either of the two vacuum lines which attach to the switch, or the switch itself.
To 74 Headlight Switch hissssss!
