wiring engine run stand
Old Aug 20, 2001 | 02:10 AM
LT1driver's Avatar
LT1driver
Default wiring engine run stand
OK, ask this before but lost data on computer. How do I hook up battery, and other wiring so I can run and start engine. Thanks. :mad :rolleyes:
Old Aug 20, 2001 | 02:31 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: wiring engine run stand (LT1driver)
http://forums.corvetteforum.com/zerothread?id=135800
Old Aug 20, 2001 | 03:15 AM
LT1driver's Avatar
LT1driver
Default Re: wiring engine run stand (BSeery)
Thanks very much, I had lost the data, now I can run tomorrow. :cool:
Old Aug 20, 2001 | 03:31 AM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Good luck, and let us know how it works.
Old Sep 6, 2001 | 09:10 PM
LT1driver's Avatar
LT1driver
Thought I would let everyone know I ran the motor about 25 minutes ago. After an initial timing problem cranked right up. Had to shut down for oil gallery leak, fixed that and ran like a champ for 45 min. Had to spray radiator with hose to keep temp below 200, other than that great. Will crank tomorrow and readjust valves. Next step, into the car after 16 years of being apart. :D :D :D :cool: :yesnod: ;) :seeya
Old Sep 6, 2001 | 09:15 PM
LT1driver's Avatar
LT1driver
For all who helped with my questions and others. Ran engine about 30 minutes ago and other than initial timing and an oil gallery leak, it ran great and ran it for about 45 minutes between 2000-3000 rpm. Tomorrow will recrank and adjust valves. Finally, after 16 years out of car. :D :D :D :cool: :cheers: :yesnod: :seeya
Old Sep 6, 2001 | 09:21 PM
ddn's Avatar
ddn
How about some pics of the run stand? I'd kinda like to fire up my new 454
Old Sep 6, 2001 | 10:32 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: wiring engine run stand (ddn)
16 years??? What's the big rush??? :lol:
Old Sep 7, 2001 | 02:48 AM
LT1driver's Avatar
LT1driver
Default Re: wiring engine run stand (yellow 72)
My stand was home made, I will try to get a picture for you before I take motor off. Yeah, 16 years long time, I hauled car around from base to base (was in Air Force) and only worked on it when home. Gone on many temporary assignments and overseas while car sat at home. Hope to have it back on road by years end. :D :chevy
To wiring engine run stand
