Vacuum Tank
Old Apr 17, 2006 | 04:47 PM
whitesnake81's Avatar
whitesnake81
Default Vacuum Tank
I want to add and additional vacuum tank and run my brakes off it, due to the cam I am running. How do you hook the additional tank?
Thanks!
Old Apr 17, 2006 | 05:43 PM
Tonys96's Avatar
Tonys96
Are you planning on using manifold vacuum...
If so, just get a vacuum checkvalve like you already have for your headlights and hook up to your source.
Usually a can will still only give you one or two brake pedal applications before you're out of vacuum, unless you use a vacuum pump. Such as this.
http://victorylibrary.com/mopar/pump-tech-c.htm
An Internet search for "Chevrolet vacuum pump" will yield many sources.
Must have a pretty lumpy cam.
Have you ruled out all possible vacuum leaks.
Old Apr 17, 2006 | 08:37 PM
rcread's Avatar
rcread
Have you considered hydroboost?
Old Apr 18, 2006 | 11:39 AM
whitesnake81
THANKS!!
To Vacuum Tank
