Timing - educate me
Old Apr 17, 2006 | 07:09 PM
72Tornado's Avatar
72Tornado
Default Timing - educate me
Okay, well as much as I know about cars/engines I must admit timing is a field I don't know much about at all. Does anyone have a paper or any links that will explain to me the specifics of timing, i.e. initial timing vs. timing @ x RPM, timing curves, effect on power output, etc. etc.? It's really something I would like to learn about. Thanks for any help in advance
Old Apr 17, 2006 | 07:15 PM
mensch53's Avatar
mensch53
Lars
http://www.corvettefaq.com/c3/HowToSetTiming2.doc
Old Apr 17, 2006 | 07:18 PM
72Tornado's Avatar
72Tornado
Thanks a lot for the link - it'll definitely come in handy.
What I'm looking for right now is more an explanation of timing itself and what initial timing is vs. timing at a certain rpm, and the effects on power output of all this...
Old Apr 17, 2006 | 07:35 PM
mensch53's Avatar
mensch53
oh man. ok...
timing refers to the point in the stroke of the piston in which the spark plug actually fires, igniting the gasoline. the initial timing is how far before top dead center the plug fires when the engine is at idle (usually 6-14ish degrees before the top of the stroke).
since the constant in this system is the gasoline combustion time, it is necessary to ignite the gasoline sooner in the stroke to make sure the gasoline burns soon enough to generate maximum power.
so, as the rpms increase, the plug spark will become more advanced to accomodate the speed of the engine. this is accomplished by weights in the distributor that are pulled by centrifugual force as their rotational velocity increases. this moves the timing to its full advance (usually 32-38ish degrees before the top of the stroke).
there is also vaccum advance in there which kicks the advance up in relation to the vaccum signal coming from the engine.
thats about the most simplistically i can describe it. i am sure others can chime in with specific tuning and power info. hope this helps...
Old Apr 17, 2006 | 07:57 PM
72Tornado's Avatar
72Tornado
Originally Posted by mensch53
oh man. ok...
Thanks a lot for the help. I knew what timing was in the basic sense - i.e. ignition related to piston/crank position - but wasn't familiar with some of the specifics. This 'Vette is my first experience with a carb'd car, so there are some differences between it and an EFI car that I need to learn yet.
Thanks again! If there's anything you want to go into more detail about, feel free
Old Apr 17, 2006 | 10:22 PM
MsVetteMan's Avatar
MsVetteMan
http://69.253.166.197/page1/page65/f...101Article.pdf
Old Apr 17, 2006 | 11:45 PM
SIXFOOTER's Avatar
SIXFOOTER
Nicely done Mensch
Old Apr 18, 2006 | 08:43 AM
mensch53's Avatar
mensch53
Well, thank you, Sixfooter. Looks like I have actually learned a thing or two around here...
Old Apr 18, 2006 | 09:16 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
There is an excellent article in the most recent edition of Corvette Fever Magazine on Timing. It is a good read.
Old Apr 18, 2006 | 12:32 PM
Chilli's Avatar
Chilli
Damn it, ignition timing confuses the HELL outta me. I can't understand why a plug would be set to fire BEFORE top dead centre. If the piston is still on it's way UP, wouldn't it be fighting against the explosion that's trying to push it back down? In my scientifically-challenged mind, it would make more sense for the gas/fuel mixture to detonate AFTER top dead centre; in other words, when the piston has just begun it's trip back DOWNWARD.
Old Apr 18, 2006 | 12:49 PM
mensch53's Avatar
mensch53
It takes time for the spark to actually ignite and burn the gasoline. Although it is a very very short amount of time, it still must be taken into consideration. So, if the engine is running at idle, and you start the ignition 8 degress of rotation before the piston hits the top of the stroke, by the time the gasoline ignites and burns completely, the piston has hit the top. That means that the full pressure created by the combustion can then force the piston down.
If you were to ignite the gasoline AFTER the top of the stroke, the piston would already be on its way down by the time gasoline burned. It would also not be compressed and you would not generate any power.
The constant here is the time it takes to burn the gasoline. If the engine is running at 800 or 8000 rpm, the gasoline doesnt burn any faster. That is the reason for the advance in a distributor. Since the piston is moving faster, you have to start the ignition of the gasoline sooner in the stroke to make sure full combustion is happening just as the piston hits the top of the stroke.
Is that any clearer, Chilli?
Old Apr 18, 2006 | 12:50 PM
SIXFOOTER's Avatar
SIXFOOTER
Its a momantum thing Chilli
Old Apr 18, 2006 | 01:03 PM
mensch53's Avatar
mensch53
Here is another good explanation (with pictures!)
http://auto.howstuffworks.com/ignition-system1.htm
Old Apr 18, 2006 | 01:04 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
oh man. ok...
Hey mensch good for you, seemed like just yesterday you were asking what a distributor was
Old Apr 18, 2006 | 01:59 PM
mensch53's Avatar
mensch53
Haha. Thanks. If you pulled my distributor, took it completely apart, threw the parts in a box and told me to get the car running again, I would probably have some problems. But, I can point to it, do an electronic module swap, set the timing, and tell you what it does - all things I definitely could not have done 3 months ago
Old Apr 18, 2006 | 02:03 PM
sweethence's Avatar
sweethence
aw c'mon you'd be surprised, I bet you could do it lickey split you've got two stars now lot to live up to
Old Apr 18, 2006 | 07:11 PM
BigBlockk's Avatar
BigBlockk
The air fuel mixture does not explode, it burns. The combustion process takes time. As engine speed goes up ignition must take place earlier to insure maximum combustion pressure is available when the piston starts its power stroke.
If the mixture reacted in the same way explosives do your engine would last about 3/4'th of its first, and only, revolution. BOOM!
BigBlockk
Later.....
To Timing - educate me
Old Apr 19, 2006 | 12:29 PM
Chilli's Avatar
Chilli
Yes, much clearer, thanks. I always just imagined that ignition to combustion was a process that was completed in an instant. It all makes sense now.
Old Apr 19, 2006 | 04:18 PM
69vettester's Avatar
69vettester
Higher octane ratings come into play because its desireable for the fuel air mix to burn smoothly all over the top of the piston, Not explode on it. So the higher the octane rating the longer the burn the more power in the stroke.
Old Apr 19, 2006 | 08:06 PM
73C34me's Avatar
73C34me
Why do drag cars retard their timing for high gear? How does this make more power?
