How does a powervalve work????
Old Apr 18, 2006 | 08:11 PM
kdcollins's Avatar
kdcollins
Default How does a powervalve work????
Grettings all.
I am curious as to "HOW" a powervalve works. The reason I am curious, when driving my car, my co-pilot (aka wife) tells me she can see a liquid flowing thru the boost referrence lines on the rear carb.
For those of you that may not be familiar to what I have done........
I have modified some 600 Holleys for use on my blower by following some guidlines Holley referrenced to me. This consisted of drilling a hole (1/8" - 3/16") thru the main body of the carb to the vacuum chamber of the powervalve and connected a line from this chamber to the intake manifold under the blower.
Now, at deceleration she has seen a liquid flowing out of the line that I installed from the rear carb toward the intake manifold. The front carb does not do this. This tells me that one of the carbs are malfunctioning but I do not know which.
Any ideas?
Old Apr 18, 2006 | 08:22 PM
norvalwilhelm's Avatar
norvalwilhelm
I run NO springs on my power valves, boost pushes them open, vacuum keeps them closed.
I used the existing port in the bottom of the carb, the one where the check valve was, I filled in the hole with devcon alumunim and then drilled a new set of ports so a line could be run from the carb base to the intake on the motor below the blower.
If you actually drilled into the gas part of the power valve you would be running so rich at idle that the car wouldn't idle at all. You would notice the car stumbling badly if you struck gas.
Your wife might see something in the lines but you could feel that flooding
Without seeing where you actually drilled the port it is hard to say if you are sucking up some gas but agian at idle with high vacuum you would think if you had a leak it would be sucking gas all the time and flooding the engine.
At coast vacuum can reach 20 inches. I run vacuum boost gages both above and below the blower.
Old Apr 18, 2006 | 08:23 PM
norvalwilhelm
Nice setup but I am not crazy about the copper lines.
A shot of mine
Old Apr 18, 2006 | 08:29 PM
Fevre's Avatar
Fevre
The power valve is muck like a second 'jet' that has a spring that pulls a valve open to allow fuel to flow, the vac sucks on the rubber seal pulling the valve closed when the vaccum is above the PV rating, if there is a hole in the rubber seal gas will get sucked through it on into the line you have so you might have a blown power valve
Old Apr 18, 2006 | 08:50 PM
kdcollins's Avatar
kdcollins
below are 2 pics showing the location of the hole drilled. Holley referrenced this area as the powervalve vacuum chamber. I did not know if fuel was present under normal conditions or not.
What effect would a "Blown" powervalve have... other than fuel being where it shouldnt? Would it hinder the idle/acceleration or would there be very little notice?
Thanks!
KC
Old Apr 18, 2006 | 08:52 PM
norvalwilhelm
If you blow a power valve the motor will not idle. It will be so rich that you can't control the mixture. If the motor idles fine, not overly rich your power valves are ok.
There is a predrilled passage in the main jet plate. When the power valve is open fuel is allowed into this passage. To richen a power valve you can drill this passage.
Old Apr 18, 2006 | 09:06 PM
kdcollins's Avatar
kdcollins
the engine does die on its own but more noticable.... when the engine comes to an idle whether from starting or at a stop light the rpms will vary from 700 to 1100. Up and down..... and the longer it idles, the worse it gets until it dies on its own. A cycle will last about 1 minute till it dies.
this is Great information guys. Thanks for the information!
Old Apr 18, 2006 | 09:14 PM
Fevre's Avatar
Fevre
Guess it could be leaking fuel in the chamber from some where else but my first guess would be the PV
Old Apr 18, 2006 | 09:24 PM
kdcollins's Avatar
kdcollins
A shot of mine
Old Apr 18, 2006 | 09:25 PM
evil herbavore's Avatar
evil herbavore
A power valve is a diaphragm device that uses vacuum levels to decide when richer A/F mixtures will occur.
The reference lines you have are a measure that helps becuase the blower is always creating vacuum in the carbs (so they would be fooled)......instead, taking a lack of vacuum in the intake to trip the power valves.
Old Apr 30, 2006 | 10:14 AM
kdcollins's Avatar
kdcollins
I replaced both powervalves on the 2 carbs with 5.5's. This has made a huge difference with the idle and there is no fuel flowing thru the air lines now.
KC
Old Apr 30, 2006 | 10:48 AM
olescarb's Avatar
olescarb
a power valve is used to cause the air/ fuel mixture to go leaner (close) when the vaccum is above its rated vaccum point. it does this to both improve fuel economy and avoid fouling the spark plugs with the richer power mixture when the power valve is open.
if there is gas going thru the vaccum lines the power valve (or gaskets) are bad!
a boost referenced power valve looks at the vaccum or boost that is in the intake system below the supercharger so the power valve closes or opens by the true vaccum (or boost) the engine has and not the vacuum created by the supercharger. the standard power valve used on most supercharged engines is 4.5 inches of vaccum.
there is a much more detailed explaination of this in the July 2006 issue of Street Rodder or also at www.automotiveu.com.
hope this helps
Old Apr 30, 2006 | 11:18 AM
kdcollins's Avatar
kdcollins
hope this helps
Perhaps my guess of 5.5's could be brought in a little closer still. This was a very interesting article to read with allot of information for the inexperienced (like me!). Thanks!
KC
To How does a powervalve work????
