Where new block for sbc?
Old Apr 19, 2006 | 12:40 PM
New's Avatar
New
Default Where new block for sbc?
Hi!
Where i can buy new cast iron block for sbc?
The motor will be about 450-550 hp and would be 4 bolts. 2-piece rear main seal.
What about World (Motown), Dart's little M or something else?
Old Apr 19, 2006 | 12:42 PM
JoeRags's Avatar
JoeRags
you can look into used blocks if you want to save money... grab one for a couple hunderd bucks. for the power level your looking for it will be fine.
Old Apr 19, 2006 | 01:01 PM
79VetteMike's Avatar
79VetteMike
What cubic inches are you looking for? You can get a new GM block at a dealership for about $700-$900. If you are wanting to stroke it anything bigger than a 396 small block, then go with World or Dart-even a 396sbc is kinda pushing it, but it's doable.
Old Apr 19, 2006 | 01:26 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by New
Hi!
Power is addictive. I am building a 383 with a GM block but If I didn't have a 4 bolt block to work with I would buy a Motown. A friend has a 400 Motown Block he is running 600 HP with 280 HP nitous shot. Pulling almost 900 HP and running 9's It's 3 years old and hasn't been apart.
Old Apr 19, 2006 | 01:50 PM
New's Avatar
New
I want to good "basic" motor. Block 350 with 4-bolt. Hp will be like i say about 450-550 hp + 150 hp shot. Motor will be normal cruising. And any way reliable street car. What kind of block you recommend for me??
Old Apr 19, 2006 | 02:31 PM
682XLR8's Avatar
682XLR8
Pulled a roller/1-piece style block from a truck at the junkyard for a shade over $100. Had it magged, tanked, and bored for $200, and am building a roller cammed 383 with it. It's one route you might think of taking.....
Old Apr 19, 2006 | 06:07 PM
James B's Avatar
James B
Im not sure where you are located at but I have an extra block that will need machining. It is standard bore, but I would take it 30 over. Ill take 200 bucks for it if you are interested.
James
red73corvette@hotmail.com
Old Apr 19, 2006 | 06:26 PM
VETTEVIC's Avatar
VETTEVIC
jegs has new 4bolt blocks that you are looking for for 629.99, (pt# 809-10066034)
Old Apr 19, 2006 | 06:42 PM
Fevre's Avatar
Fevre
That is the way to go.
To Where new block for sbc?
