Does anyone run these?
Old Apr 19, 2006 | 08:27 PM
sperkins's Avatar
sperkins
Default Does anyone run these?
245/60/15 on 15x8 Rallys?
If so, any clearance problems with suspension?
Looking to run on 68 convertible. (And yes I know 68 came with 15x7's)
Thanks..
Old Apr 19, 2006 | 08:50 PM
Corey_68's Avatar
Corey_68
Since I'm running 275/60/15's I'd say you shouldn't have any problems.
Old Apr 19, 2006 | 08:55 PM
Cory1970's Avatar
Cory1970
Mine are 255/60/r15's with no issues, but 70-72 had a slight flare in the fender
Old Apr 19, 2006 | 09:00 PM
Gordonm's Avatar
Gordonm
I had that size for years with no problems.
Old Apr 19, 2006 | 09:08 PM
DZRick's Avatar
DZRick
Default Cory_68
Cory_68,
Are you running 275's with no mods at all?
Rick
Old Apr 19, 2006 | 09:12 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I am running those now on my 69 vert and there are no problems.
Old Apr 19, 2006 | 10:16 PM
Corey_68's Avatar
Corey_68
Originally Posted by DZRick
Cory_68,
Rick
I relocated my e-brake bracket (though some here didn't have to). I have since switched to offset T-arms and running 245's on the front.
Old Apr 19, 2006 | 10:53 PM
DZRick's Avatar
DZRick
Thank-you sir
Rick
Old Apr 20, 2006 | 02:07 PM
68sbShark's Avatar
68sbShark
Thanks..
I have these on my '68 coupe. I did however relocate the e-brake bracket to the top of the t-arm. The PO must have had some issues, because the drivers side e-brake bracket was torn off. Looked almost as if the tire flexed in a turn and just ripped it to shreds. The cable was cut and just tucked under the brake line. Man do I hate bubba.
The 245 is not a real good fit for a spare though (ask me how I know). You can get it in the tub, but man is it a pain.
~Rich
Old Apr 20, 2006 | 02:09 PM
stingraymaniac's Avatar
stingraymaniac
i have 245/60/15 all around on rallyes and they fit great
Old Apr 20, 2006 | 02:11 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Thanks..
235/60/15 on 7" here with pleny o room ours will take up to 255 ant that fill the fenders completley
Old Apr 20, 2006 | 02:24 PM
68vertible's Avatar
68vertible
I'm running 255/60 15's on 8" TT II's and the backs are close to the e-brake brackes but should be fine. The fronts are slightly rubbing on the front fender well tips so I'm going to the 235/60 15's. This leaves me with two extra 255's but I've just stroked to a 383 so I'm betting I'll need two new rears pretty soon anyway.
To Does anyone run these?
