Which type of engine mounts
Old Aug 20, 2001 | 04:50 PM
ZD75blue's Avatar
ZD75blue
Default Which type of engine mounts
I am wondering what type of engine mounts will last the best all around performance?
Metal interlocking
Poly Urathane
Ruber clam shell
What are you guys running and are you happy with them?
ZD
Old Aug 20, 2001 | 05:42 PM
Clink69's Avatar
Clink69
Default Re: Which type of engine mounts (ZD75blue)
Solid mounted Metal will rattle your brains out., I had these in my BB 454 and they made everything rattle. Not sure what Metal interlocking is? :crazy:
Old Aug 20, 2001 | 06:07 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Default Re: Which type of engine mounts (clink)
clink,
A good quality standard interlocking motor mount will work very well unless you are running lots of torque. I am assuming that you have a small block. The same mounts were used for both big and small block motors. So a small block would have to make some real torque to exceed the ability of a big block to break a mount. The standard mount will also absorb vibration and make your teeth last longer.
Ed
Old Aug 20, 2001 | 06:55 PM
ZD75blue's Avatar
ZD75blue
at stop lights in radles your brains out but has the stock rubber chunk between the engine and the frame
Has anyone had sucess with poly urathane?
so far I'm leaning toward regular style or urathane
ZD
Old Aug 20, 2001 | 07:33 PM
theandies's Avatar
theandies
I have Energy Suspension's Poly safety (locking) mounts on my ZZ4. I like them. The old mounts were rubber non-locking and when I removed the left hand bolt during the engine change the mount fell on the floor of my garage!!! :eek: :eek: :eek:
John
Old Aug 20, 2001 | 08:41 PM
Sleper's Avatar
Sleper
I am running stock mounts. I blew my left one shortly after rebuilding my car. I put in another stock mount but chained the left side of the block. Not tight but left some movement. The engine rotates about 1" now and have not blown the mount. Seems to work great. Good luck.
Old Aug 20, 2001 | 10:02 PM
nastee383's Avatar
nastee383
Default Re: Which type of engine mounts (Sleper)
If your car is making a substantial amount of hp/tq get Energy Suspension poly mounts (trans also). They'll likely be the last ones you'll ever have to buy.
Old Aug 20, 2001 | 11:08 PM
ScubaJKD's Avatar
ScubaJKD
Default Re: Which type of engine mounts (nastee383)
I am running the poly motor, tranny, and rear diff mounts. Should be solid as a rock but will probably rattle my teeth out. I will post more when I get to test them out. Good news is that I will never have to replace them. Even if they suck :lol:
To Which type of engine mounts
